Nov 27, 2013 2:42 AM UTC
Context Sensitive Help in Robohelp not working for Web Help output
Hi
I am using Robohelp 10 and the output type is Web help.
I have copied only the WebHelp Folder generated to the Weblogic Application Server and not the entire Project Folder generated by the RoboHelp.
Now that I am able to access the help from the URL  as follows
http://localhost:9900/rbh/WebHelp/index.htm,
But when I try to pass the Map Id along to get the Context Sensitive Help , I still am getting the same first starting page, the URL I have used is
http://localhost:9900/rbh/WebHelp/index.htm#<id=3>.
I have copied the Map Id file to the App Server  into the WebHelp Folder.But still Iam not able to get the Context Sensitive Screen.
Am I missing something. Please suggest.
sdesab,
    Willam van Weelden
    Nov 27, 2013 8:26 AM UTC
    Have you included the context sensitive info in your output? This is
    something easily overlooked.
    In the SSL settings, go to Content Categories and select the category.
    Make sure all files in the section Map Files are checked. Regenerate and
    it should work.
    Greet,
    Willam
    Nov 27, 2013 3:39 PM UTC
    William,
    Thanks for the tip, verified the Map Files, but it did not resolve the issue.
    Mark
    Willam van Weelden
    Nov 27, 2013 9:49 PM UTC
    Can you check the file whcshdata.htm (in the output) in notepad? Do you
    see a list of your map id's in this file.
    Greet,
    Willam
