Problem with Context- sensitive (CSH ).chm help (CSH .chm help generated using CSH Winhelp
Hi ,
I have a context sensitive Winhelp Project that needs to be converted to a context- sensitive .chm file using RoboHelp 7.0. The context- sensitive Winhelp Project was created using RoboHelp 2002.
I have used RoboHelp for HTML to convert it into a context –sensitive .chm file. Is this the right way? Or should I have used RoboHelp for Word?
The .chm is generated fine, but according to the technical team the context-sensitivity no longer works when the .chm is integrated into the application. I understand that the tech. team needs to use the .h files to integrate it and make it context-sensitive, but they are of the opinion that with the old files (Winhelp Project), just the old .hlp files was good enough to make it context-sensitive.
How should I approach this ? What are the files that I need to give the developers so that they can integrate it into the application, other than .h files. What do they need to do? They do not have RoboHelp on the system.
Would appreciate any insight on this.
Thanks.
UR
Thanks.
UR
