Douglas_Campbell
RH reverts to default styles when I compile help system, instead of using designated custom styles
  • March 13, 2012
  • 635 views
I have created a custom template in RH9 running on Windows XP, patched to most recent update. The template includes a number of custom styles - we aren't using any of the default RH styles. In the RH authoring environment it looks great, but when I compile the help system, it seems to revert to the default RH pargraph styles.
How can I resolve this issue?
Thanks in advance,
Douglas
Douglas_Campbell
I forgot to add - this is specifically an issue in a FM>RH conversion template.
Peter Grainge
Question moved to correct forum.
See www.grainge.org for RoboHelp and Authoring tips
@petergrainge
