RH8 - Publishing Merged Projects with AIR Browserbased Help
i have one master project with 5 subprojects. When i make an Output with Adobe Air "Browserbased Help" is the preview ok, all tables of Content from all projects are included.
When i publish it to our webserver i first got a grey screen with an loading error.
I discovered that the link in the start site to the included file ac_oetags.js is incorrect because of upper and lower case writing. When i change the link, the site appeared correctly - but unfortunately only with the table of content of the main project.
Is it possible to merge Projects with Browserbased Help?
Has anybody an idea what went wrong?
Thanks for your support!
Steffan
