Robo Help 9 Web Help Publish Problem
  • January 14, 2011
  • 715 views
I am trialling V9 of RoboHelp and when I am publishing to Web Help all I get is the skin with no data. I am publishing to my file system. Can anyone help? Thanks
    Willam van Weelden
    Are you using Chrome? Chrome doesn't support locally installed webhelp because of a security restriction. There is a workaround. See snippet 130 on http://www.grainge.org/pages/snippets/snippets.htm.
    Greet,
    Willam
    NaidahsAuthor
    Thank you very much, that was great and fixed the problem
    Naida
