Dec 21, 2023 6:49 AM UTC
Tagging help ids with topics for context sensitive help pages in CHM and Frameless output
The CHM file is generated and bundled as a single file in a . CHM form by the RoboHelp tool to work in an application, and in a Frameless output, each help file is available as a separate HTML file.
Could someone explain internally within the application how the tagging helps IDs with context-sensitive topics in a CHM and Frameless output is done?
    Peter Grainge
    Dec 21, 2023 8:34 AM UTC
    RoboHelp simply applies the Map ID to the topic. It's then up to the developers in their software to make a call to the Map ID. It's their software doing the work.
    See https://www.grainge.org/pages/authoring/rh_tour/rh2022/outputs/calling_csh_help.htm
    ________________________________________________________
    My site www.grainge.org includes many free Authoring and RoboHelp resources that may be of help.
    Aug 22, 2024 6:29 PM UTC
    Hi Peter,
    It seems that the link is broken.
    Barry
    Peter Grainge
    Aug 22, 2024 6:36 PM UTC
    Yes and the 404 page you got explains why and gives you a link to the home page of my site. The page you want is in the TOC.
    https://www.grainge.org/RoboHelp/Calling_Help/Calling_Help.htm
