Oct 1, 2014 2:15 PM UTC
Using a "Web Application Help" project, WebHelp>Generate ... gives me a blank blinking index.htm
What am I doing wrong, or what settings should be set in order to get the WebHelp index.htm to generate correctly.
Jeff_Coatsworth
Oct 1, 2014 2:21 PM UTC
Where are you looking at your WebHelp – locally or on a web server? What browser are you using? What version of RH are you using to create the WebHelp?
