HELP! Text turned to boxes with x's through them
  • August 21, 2023
  • 7907 views
Hi all,
The text on my adobe acrobat PDF i am working on turned into this! Let me know how i can fix this.
This is crazy. Getting the same issue with boxes. Every since last week when we got a message in Acrobat stating: Type 1 fonts will no longer be supported starting 2023. Your document contains Type 1 fonts. We get PDF files most of the time from our clients and Arial MT/Courier New SOMETIMES comes over with those boxes but always EMBEDDED. How is this possible????? I can remap font in PDF but need to know why this is happening. I also tried to Repair Installation and think it did it but not positive. HELP! LOL
S_S
Hi @Dawn33168716mn47,
Hope you are doing well. Sorry for your experience with Acrobat!
We released an update that contained a fix for this issue with rendering Type 1 fonts(ver. 2024.003.20054). Would you mind updating the application to the latest version and letting us know if that worked?
Also, if these are not Type1 and you still see the issue, please share a screenshot of the view you see and the Document Properties-> Font tab, so we can get it checked.
-Souvik
S_S
Hello Everyone,
We are live with the next release(2024.003.20112).
Please update the app to the latest version and let us know if the issue is fixed.
Souvik
Bevi Chagnon - PubCom.com
The "tofu" boxes with X indicate that the fonts used in the original source file (such as in MS Word) were not embedded into the PDF when it was exported.
Three solutions:
  1. Figure out which fonts are missing in the PDF and install them on your computer. You can view the PDF's fonts in File / Properties / Fonts tag.
  2. Return to the original source file (MS Word or something else), and re-export the document to PDF, this time checking the options to embed all fonts.
  3. You can try to force-embed the fonts into the PDF with Acrobat's built-in Preflight utility, but you may or may not have the original fonts on your computer to do that.
See detailed instructions in this other post: https://community.adobe.com/t5/acrobat-discussions/scrambled-text-when-viewing-pdf-documents-in-acrobat-standard-xi/m-p/10651537#M152983
|    Bevi Chagnon   |  Designer, Trainer, & Technologist for Accessible Documents ||    PubCom |    Classes & Books for Accessible InDesign, PDFs & MS Office |
I had the same thing happen, but it was a PDF that I had edited, adding text boxes, and then I scanned pages into the end of the document and all of the text turned to "tofu" boxes.  Is there a way to prevent this?  I was using Courier Std or another regular text font.
