lisas98531558
Jun 21, 2015 2:50 PM UTC
Installation Problem: IMSLIB not found. Acrobat Services will not work.
Just installed Acrobat Pro DC through Creative Cloud.
Upon opening for the first time, I get the pop up "Installation Problem: IMSLIB not found.  Acrobat Services will not work."
I've tried uninstalling, running the Acrobat cleanup tool, restarting and re-installing through CC, and still get the same error.
Any ideas?
AadeshSingh
AadeshSinghCorrect answer
Jun 28, 2015 3:45 PM UTC
Hi Lisa,
Please uninstall Adobe Acrobat DC using the CC cleaner tool, restart your computer & reinstall it using this link Free Acrobat Pro DC | Download Adobe Acrobat Pro DC free trial.
Let me know if the issue persist.
Aadesh
andrebGFA
Mar 31, 2016 1:58 PM UTC
I uninstalled several times using the CC Cleaner tool and the same message keep appearing. My OS is Win 10.
It just seems that to many people have the same problem? In the first place it is a mission to get Adobe Creative Cloud to install. Every uninstall and download cost people data. Adobe surly you can come-up with a better solution!!
Not even a help desk to speak to?
Jan 11, 2017 5:51 PM UTC
Typical Adobe.  No solutions to problems that they are ell aware of.   They take your money.  They provide no service.
felix kim
Mar 31, 2016 1:21 PM UTC
I have same issue. And tried all the procedures described in this page but all failed.
When I tried to install Adobe Application Manager, I got an error such as "Initialization Failed in Install Program", translated from Korean error message to English.
I have nothing to do any more.
Is there new solution?
Kislow
Nov 3, 2015 9:42 AM UTC
Hi all,
All the mentioned solutions did not work for me. However, by installing "adobe application manager" all the error messages I was getting disappeared.
Kadir Islow
darthdunk
Mar 8, 2016 10:16 PM UTC
Agreed Kislow - I had uninstalled that app (thinking I didn't need it) and started getting this error. Now after reinstalling, everything seems to be working.
Netizenxero
Sep 27, 2015 3:25 AM UTC
I am having the same issue, however I cannot seem to find the option to deactivate and reactivate the creative cloud package through photoshop.  I have tried uninstalling and reinstalling Acrobat several times in several ways, each time with no change.
I did a search for instances of IMSLib.dll on my hard drives, and here are the folder locations of the instances I've found:
C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\P7\x64
C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\P6
D:\Program Files\Adobe Premiere Pro CC 2015
D:\Program Files\Adobe Photoshop CC 2015
D:\Program Files\Adobe After Effects CC 2015\Support Files
D:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCLibrary\js\node_modules\node-imslib\IMSLib\libraries\win32\Release
Keeping in mind that before I installed Creative Cloud, I set up Windows 10 to install all programs to the D: (secondary drive) instead of C: (Where Windows is installed).  Does any of this help?
webmanSMP
Sep 16, 2015 6:27 PM UTC
Having the same issue. Tried all the suggestions. None of them work for me. Can I get a solution for this error, please?
Thank you.
Sep 26, 2015 3:02 AM UTC
I don't own Photoshop - any suggestions ?
Sep 30, 2015 8:32 PM UTC
Same problem. No Photoshop installed. I installed with the directions on this page:
Creative Cloud Help | Deploying Adobe Acrobat
AadeshSingh
Hi Lisa,
Aadesh
lisas98531558
Jul 20, 2015 12:26 AM UTC
Still issue.  Tried a direct install of Adobe DC and via Creative Cloud.  Same error about the IMSLIB file.
Anubha Goel
Jul 20, 2015 4:57 AM UTC
Hey lisas98531558,
Thank you for your response.
IMSLIB.dll file is associated with Adobe Photoshop program as a part of Creative Cloud application.
You might try deactivating and reactivating the full Creative Cloud package using Photoshop (from the Help menu) and then restart the application.
Now, check Acrobat might also start working without any further problem.
Let me know how it goes.
Anubha
