Jul 9, 2009 2:39 PM UTC
Need Help Fast Re: Problems with capturing in Adobe Premiere Pro CS4
I am working on a project with a deadline.  I am using Adobe Premiere Pro CS4.  My camera is a Sony Digital Video Recorder DCR-HC26.  My computer is a Dell with OS of Windows Vista.  I have been capturing numerous clips from hundreds of mini digital video cassettes.  Yesterday, I attempted to capture from a Radio Shack Mini DV Metal Evaporated mini DV digital videocassette.  For whatever reason it will not capture.  I have never used one of these tapes before.  Could it be the tape?  After I click on "Capture," the screen shows NO PICTURE of sound, however, it plays on the camera.  It can't be the camera settings because all the other tapes work. . .  Any advice?
    Jul 9, 2009 2:42 PM UTC
    you need to post in the correct forum olivia.
    http://forums.adobe.com/community/premiere/premierepro_current
    olivia_8Author
    Jul 9, 2009 2:53 PM UTC
    Sorry!
    Jul 9, 2009 4:19 PM UTC
    not to worry. happens all the time!
