Apr 17, 2012 5:18 PM UTC
Urgent Help with after effects! please help me solve this problem A.S.A.P
Well.. after effects cs5.5 loads up perfectly fine.. if i dont do any editing at all it is fine. But once i start editing it's goes all fine for about 30 seconds.. for example if i want to use the green brush
tool.. it works etc but then suddenly it freezes. when i try and use the tool it wont do anything! the hole thing freezes then i have to do ctrl + alt + delete.. It keeps saying not responding.
I need urgent help.. i don't know why it keeps doing it! it does it when I use anything but it just freezes.. my pc is a gaming pc pretty good.. dual core etc 64bit! also dont say that my pc isnt good enough because it is! i could use cs4 on my laptop and that was alot lower specifications.. ive updated my nvidia drivers etc..
Someone please help, I miss my editing .
    Claudio González
    Apr 17, 2012 5:25 PM UTC
    This forum is only for discussions on the forums themselves. The After Effects one is here:
    http://forums.adobe.com/community/aftereffects_general_discussion
    Apr 17, 2012 5:30 PM UTC
    Oh thanks I posted there instead.
