Objektivkorrekturen
Aug 02, 2024 Aug 02, 2024
Seit dem Umstieg von Nikon D610 auf Nikon Z6III wird bei RAW Aufnahmen bei Profilkorrekturen nur noch Integriert angezeigt. Bei der D610 wurde immer das benutzte Objektiv angezeigt, das ich auch auf der Z6III verwende, . Ich benutze Lightroom Classic 13.4 aber auch in der Vorgängerversion 13.3.1 wird nur Integriert angezeit. Manuell kann ich Tamron auswählen und sofort wird dann auch das Objektiv SP 24-70 F2,8 angezeigt. Hat jemand eine Idee?
TOPICS
Windows
358
LEGEND ,
Deleted
Re-wrote
I reconsidered your post, and I think I misunderstood it. Likely a translation issue.
At first I thought it was about this:
But while I do not have a Nikon Z6III or a sample NEF from a Z6III, I do have a sample from a Z6II, and that issue in the above screenshot does not occur (at least in the one sample)
Can you post screenshots or a video capture to describe your problem?
Aug 09, 2024 Aug 09, 2024
Attached two Screenshots. First when selecting Enable Profile Corrections I get as Lens Profile "Integriert", Selecting Tamron, I get the correct lens Tamron SP 24-70mm F2.8. For me it seems that the information is available in NEF but will not be displayed when selecting Profile CorrectionsIntegriert.jpgObjektiv.jpg
quote
Since switching from Nikon D610 to Nikon Z6III, RAW images only show Integrated when making profile corrections. With the D610, the lens used was always displayed, which I also use on the Z6III, . I use Lightroom Classic 13.4 but even in the previous version 13.3.1 only Integrated is displayed. Manually I can select Tamron and immediately the SP 24-70 F2.8 lens is displayed. Does anyone have an idea?
By @Norbert28155824xuyk
It is not clear from your post what lens you are using.
Is it the Tamron SP 24-70 F2.8 or a different lens?
And do you see Built in lens profile applied like in the screenshot posted by @GoldingD ?
Aug 10, 2024 Aug 10, 2024
Yes my lens is Tamron 24-70 / F2.8. Please see my screenshot I made for GoldingD
Aug 13, 2024 Aug 13, 2024
If you choose Save new lens profile defaults under Einrichten, it should work for new images that you import taken with this lens.
