P: Refine Edge > Shift Edge doesn’t shift edge of selection [PS 4.8 on iPadOS]
Community Beginner ,
Aug 14, 2023 Aug 14, 2023
Issue: Refine Edge > Shift Edge doesn’t shift edge of selection
  • Photoshop version: 4.8 (20230724.486)
  • OS: iPadOS
Steps to reproduce:
  1. Open image and under Selection Tools, Select Subject
  2. Click “refine edge”
  3. Move “shift edge” slider
Expected result: edges of selection will expand or contract (did this for me as recently as 8/4)
Actual result: selection edges do not move
Bug Unresolved
TOPICS
iPadOS
2.5K
24 Comments
Aug 27, 2023 Aug 27, 2023
Have the same bug. Very frustrating!
Explorer ,
Aug 31, 2023 Aug 31, 2023
Same here.  I got so excited after watching one of the videos by Russell Brown only to see that the Shift edge doesn't work on the iPad.  If it matters, I'm using an iPad Air 5 running ios 16.6 and PS 4.8.
Explorer ,
Not sure if it matters, but I used the Marquee rectangle tool to create my mask instead
 of select subject.
Sep 01, 2023 Sep 01, 2023
Same here, I've done everything one can do to troubleshoot this issue w no avail. Everything works likes it's supposed to,... except the edge shift.
Adobe Employee ,
Sep 07, 2023 Sep 07, 2023
Hi @Jan309549902ak1 ,thanks for calling out! We are currently investigating the issue and plan to have a fix soon.
Explorer ,
Oct 11, 2023 Oct 11, 2023
Any update on a fix for this?
Explorer ,
Dec 12, 2023 Dec 12, 2023
Any ETA on getting this fixed?  I see another update was released and this still hasn't been fixed.
Dec 16, 2023 Dec 16, 2023
Nah man, #1. They’ve got their $$$. #2 They They bow only and answer to AI. They shall not be bothered by us little folks.
M.Patterson
Explorer ,
Feb 07, 2024 Feb 07, 2024
Seriously, any update?
Feb 28, 2024 Feb 28, 2024
Same problem. Awaiting solution
Explorer ,
Mar 28, 2024 Mar 28, 2024
Its been nearly 7 months and you guys havent fixed this issue.
Apr 19, 2024 Apr 19, 2024
How is this still an issue?
May 01, 2024 May 01, 2024
Hi! Still not working..
Explorer ,
Jun 04, 2024 Jun 04, 2024
Seriously, still no fix???
Jun 06, 2024 Jun 06, 2024
Here's my customer service experiences.. ( groundhog day). After 11 months and 3 or 4 call in's.
  • I get ran through the gauntlet of the same troubleshooting steps that didn't work the last time
  • I'm put on hold while he looks @ notes, supervisor, community etc
  • They can't figure it out but they have a team working on it, it shouldn't be long and he'll call me when it's fixed. .
  • After all that hype, we hang up.. Check my email > case is closed> if I have any concerns. Call Customer
  • No follow ups, no emails, no compensation. I take that back.. I do get a heart felt email asking me for my feedback to help shape the future of PS express and to take a survey on it. It's insulting.
  • I sooo don't ever use PS express. Never... Only once or twice just trying it out. How can they keep introducing new features and not fix the current ones that are broken? My only conclusion to all of this is. They don't care
Jun 09, 2024 Jun 09, 2024
I came here for a solution to this same issue.  Very discouraging to see that it was reported almost a year ago with no resolution.  Indeed, the only reasonable conclusion is that they don't care.
Jul 23, 2024 Jul 23, 2024
Yes, still broken for me as well.
iPadOS 17.5.1 on M1 iPad Air
Photoshop 5.5.2 (20240429.560)
Aug 03, 2024 Aug 03, 2024
Doesn't work for me either
Engaged ,
Aug 04, 2024 Aug 04, 2024
Hello Adobe. As a common courtesy for paying customers - Is there a plan to fix? If yes, when? If no, why? Thanks for listening.
Sep 01, 2024 Sep 01, 2024
9/1/24 - still not fixed.
Sep 02, 2024 Sep 02, 2024
What's funny ( but not) is today I. #I told them that after 2 years of them getting my $$ that they should've had this fixed by now and it they don't have a solution in 2 months I might be forced to take it to the next level. #2 fix the broken edge shift not working or to take down the tutorial explaining how to use edge shift under the refine edge submenu. LOL. The short version of this would've been "don't hold your Breath "
* I told them to have AI fix it.
M.Patterson
Dec 13, 2024 Dec 13, 2024
Adobe, it's beginning to look a lot like Christmas. Can we get this fixed? I've been nice all year long but I'm afraid I'll lose my sh*t. We need to expand/contract selections before doing Generative Fills. This is a major oversight.
Apr 05, 2025 Apr 05, 2025
2.5 out of a 3 yr paid subscription 'should be ample time to fix an issue. My photography careen path has been shunted from not exploring photography w/ subjects that require intricate features to edit ie. Hair, trees. You all can keep producing new features for other apps but can't fix the broken ones that you bill ppl for. 4 to 5 times over 2.5 years I get the some blah blah blah I will give it to my beoekend support tear and will email you w/ a fix. Guess who never received an email w/ a fix? I don't have a desktop. I only have the iPad Pro 12.9" 6th gen. Utterly disheartened IS HOW I FEEL AFTER BEING LET DOWN, LEFT BEHIND, IGNORED, WHILE STILL PAYING FOR THE ONLY THING THAT REALLY BROUGHT ME SOME TYPE OF ENTERTAINMENT IN THIS GARBAGE AZZ LIFE. THERE IS ABSOLUTELY NOTHING I HAVEN'T DONE THAT YOU ALL HAVE SUGGESTED AND THAT I'VE TRIED ON MY OWN. I'VE DELETED CLOSED THE ACCOUNT SIGNED BACK UP BOUGHT ANOTHER SUBSCRIPTION. ERASED THE DATA  I'VE DONE EVERY THING THAT I COULD POSSIBLY DO TO FIX THIS ISSUE WITH EDGE SHIFT I THINK IT'S SAFE TO SAY AFTER 2 1/2 YEARS YOU ALL DON'T KNOW HOW TO FIX IT EITHER.
