Problemas com reprodução de audio no premiere - Problems with audio playback in premiere
  • July 17, 2023
  • 4 replies
  • 415 views
[PT-BR] Estou tendo problemas com as preferências de hardware de audio no premiere pro, como é possivel ver no video quando uso o autofalante do notebook tudo funciona perfeitamente, mas quando tento usar os fones de ouvido apenas o audio é reproduzido e a timeline e o preview param
[EN-US] I'm having problems with the audio hardware preferences in premiere pro, as you can see in the video when I use the notebook speaker everything works perfectly, but when I try to use the headphones only the audio is played and the timeline and preview stop
PC SPECS
Notebook Dell g15, Core i5 12500h, Geforce RTX 3050, 16GB RAM, 512 GB SSD | PREMIERE 23.5V  | Windows 11 Pro Versão 22H2
Correct answer Ann Bens
Set Default Input in the Audio Hardware in the Preferences is set to No Input.
Thanks, after i made the process of this video https://www.youtube.com/watch?v=jdpG79no3oQ
what you said to do worked
Might want try again.
Having the mic selected when not using it can cause issues.
I tried but it didn't work
