I was using a text stroke using a paint bucket
- December 6, 2024
- 2 답변들
- 538 조회
Hello, I'm a user who has been using subtitles created using the paint bucket effect for text strokes from the 2023 version.
Of course, I know that stroke options exist in the text default graphics options.
But the stroke that I made and used
I made and used a stroke in the form of wrapping all the basic graphics made using text, stroke, and shadow.
But now that the paint bucket is gone, these methods are not available.
It is a designed subtitle that is used over three stages, including subtitle creation using srt, design using style, and preset effect.
However, if you use after effects to create design subtitles, you won't be able to use this method at all.
It doesn't have to be a paint bucket.
I want you to provide a basic stroke effect that can be used in all elements such as images, texts, etc.
I posted an example of the caption as an image attachment
I tried to recreate it using effects like drop shadow, Alpha Glow, and long shadow, but I couldn't create the design that I wanted
