Arms not attaching to body
Using
Character Animator Version 23.1
Device : Macbook Pro with M1
macOS : Ventura 13.2.1
Tested with both Apple silicon and intel version.
The arms are not connecting to the origin automatically. I have tested my custom pupeet and even lots of sample puppets from adobe.
This is for the steps outline here for the timestamp https://youtu.be/hK-DjtiPzRs?t=1612
The green dot line does not appear, also moving the dragger does not change to green square box.
Please validate if this is a bug or something has changed since this video was made.
