Aug 15, 2023 1:22 AM UTC
Open for Voting
P: Refine Edge > Shift Edge doesn’t shift edge of selection [PS 4.8 on iPadOS]
Issue: Refine Edge > Shift Edge doesn’t shift edge of selection
  • Photoshop version: 4.8 (20230724.486)
  • OS: iPadOS
Steps to reproduce:
  1. Open image and under Selection Tools, Select Subject
  2. Click “refine edge”
  3. Move “shift edge” slider
Expected result: edges of selection will expand or contract (did this for me as recently as 8/4)
Actual result: selection edges do not move
Apr 20, 2024 6:44 AM UTC
How is this still an issue?
Mar 29, 2024 12:09 AM UTC
Its been nearly 7 months and you guys havent fixed this issue.
Mar 28, 2024 9:33 PM UTC
Feb 28, 2024 5:58 PM UTC
Same problem. Awaiting solution
Feb 8, 2024 4:21 AM UTC
Seriously, any update?
Dec 17, 2023 1:06 AM UTC
Nah man, #1. They’ve got their $$$. #2 They They bow only and answer to AI. They shall not be bothered by us little folks.
M.Patterson
Dec 12, 2023 9:53 PM UTC
Any ETA on getting this fixed?  I see another update was released and this still hasn't been fixed.
Oct 11, 2023 4:18 PM UTC
Any update on a fix for this?
Nidhi  shree
Adobe Employee
Adobe Employee
Sep 7, 2023 7:07 AM UTC
Hi @Jan309549902ak1 ,thanks for calling out! We are currently investigating the issue and plan to have a fix soon.
Sep 1, 2023 4:02 PM UTC
Same here, I've done everything one can do to troubleshoot this issue w no avail. Everything works likes it's supposed to,... except the edge shift.
