Aug 15, 2023 1:22 AM UTC
Open for Voting
P: Refine Edge > Shift Edge doesn’t shift edge of selection [PS 4.8 on iPadOS]
Issue: Refine Edge > Shift Edge doesn’t shift edge of selection
  • Photoshop version: 4.8 (20230724.486)
  • OS: iPadOS
Steps to reproduce:
  1. Open image and under Selection Tools, Select Subject
  2. Click “refine edge”
  3. Move “shift edge” slider
Expected result: edges of selection will expand or contract (did this for me as recently as 8/4)
Actual result: selection edges do not move
Aug 31, 2023 7:46 PM UTC
Not sure if it matters, but I used the Marquee rectangle tool to create my mask instead
 of select subject.
Aug 31, 2023 3:27 PM UTC
Same here.  I got so excited after watching one of the videos by Russell Brown only to see that the Shift edge doesn't work on the iPad.  If it matters, I'm using an iPad Air 5 running ios 16.6 and PS 4.8.
Aug 27, 2023 8:17 PM UTC
Have the same bug. Very frustrating!
