May 15, 2025 12:40 PM UTC
Open for Voting
25.2 - Audio levels not pasting to other clips & odd audio mixer behaviour.
As a timeline gets more complicated copy/pasting clip audio levels stops working. What's weird is that for some clips it will work fine, but for others it won't. At the same time adjusting a clip's audio level with the clip mixer will not change the horizontal level line in the timeline, (although the level will change). You can still adjust the levels by moving the line vertically, but this then doesn't drive the audio mixer. Again, this is completely random - some clips will be affected, but some will not. For instance I've got a timeline where audio on tracks 1-3 work as expected, but on tracks 4 and above it does not. Rolling back to v24 fixes the problem.
This has been seen by a few of us working on Apple Silicon computers.
Happy to share a project, although I can't do that publically.
May 15, 2025 12:41 PM UTC
I should add that this is in 25.2.3 and is the same in the latest beta (25.4)
