No Audio Playback in Premiere Pro 2023 - Audio Meter shows that it works - not muted
- June 4, 2024
- 8 replies
- 1533 views
Hello!
I encounter a really annoying problem which appeared out of nowhere.
Specs:
Processor --> Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz 2.80 GHz
Installed RAM --> 16.0 GB (15.9 GB usable)
System type --> 64-bit operating system, x64-based processor
Windows 10 Home
Specific problem:
- I have Premiere Pro 2023 and Premiere Pro 2024 both installed. For some reason, the audio playback stopped working on Premiere Pro 2023, but it works on Premiere Pro 2024. They have the exact same settings in Audio Hardware. I checked Audio Track Mixer and Audio Clip Mixer, everything is alright. Layers are not muted and actually all the settings are the same as in previous days. But for some reason only Premiere Pro 2023 sound doesn't work.
Anything outside of Premiere Pro 2023 works, including Premiere Pro 2024, but I need to finish the project in 2023, not 2024 due to my client who insists working on 2023 version.
I tried everything, reset, uninstall/reinstall, restart windows, make new project and put different types of audio files, with and without headphones, moved the audio layer on other layers, enable/disable, mute/unmute, nothing works. When I export the timeline, audio plays, it's just in the timeline that it doesn't work, and only in Premiere Pro 2023.
I tried multiple wav audio files also from this project i'm working on, but also from some stock music websites. I also tried to create a new project and import the whole project with problems, didn't work. I tried to work on Premiere Pro 2024 and export an XML file to use in Premiere Pro 2023, but the whole project has problems in keeping my cuts correct with a nested file.
In the screenshot I provided I wanted to show that the program shows that the file has sounds, has audiowaves, it's just that I won't hear anything within the program, if I export the timeline, the sound is there.
Is there any solution for this problem?
Thank you for your patience!
