Jun 12, 2025 9:02 PM UTC
Open for Voting
P: Audio of AVCHD files in .MTS format with PCM audio does not play correctly - sounds like noise
[Subject line updated by moderator]
Using the latest version of PP (25.3.0) I was working on a project containing MTS video files, and all of a sudden the next day I opened up the project, and all of the audio tracks of the clips had max volume static (and nothing else). It had been working for several days. In the audio track timeline, it displays as just a solid bar, rather than a typical bar with variying levels as you'd expect (see attached). It is like this in the editor, and also if you export the video.
I messed with this for hours, including contacting Adobe Support Chat for about an hour. They weren't able to help. They left me with suggesting that I make sure all of my Windows updates were in place. I did that and still nothing. I messed with my video card drivers - making sure they were on the latest version, etc. I downloaded the AC3/AC4 codecs from the other Adobe post talking about MTS files not working in the latest version of Windows - that didn't help. I also have cleared cache several times, and I tried re-insatlling the latest version of PP.
If you open the files by themselves in Windows, they are fine. The audio is normal. They work fine in MS Clipchamp. They also work fine an older version of Premiere Pro that I downloaded (24.6.5). So, theoretically, I could start over and do this in 24.6.5, but I'd prefer to continue working in the latest version. I'm sure this is codec related or something, but I have hit a brick wall.
Has anyone else had this specific issue, and have you found a solution? Thanks
Jul 16, 2025 5:03 PM UTC
Adobe Premiere aktardığım Avchd cihazlarının sesi cızırtılı geliyor.
Standart bir oynatıcıda açtığımda sorun ortadan kalkıyor.
Jul 15, 2025 8:30 PM UTC
Why not just use an older version of the software?
Jul 15, 2025 2:34 PM UTC
Yep, same problem.  Until they get it fixed, transcode to another format in any non-Adobe (or old Adobe) transcoder.
Jul 15, 2025 1:53 PM UTC
I have the same issue. Recording on a Sony PXW z90 camcorder, editing on Premiere Pro 25.3.0. MTS files just have the scratchy static. Before it was just zero audio and now it's the noise.
Jul 15, 2025 12:29 AM UTC
Any non-Adobe transcoder will work. I used Handbrake to go to MP4.  All Adobe transcoders are affected right now. (If you have a copy of CS6 lurking on an old machine, it would work too.)
Jul 14, 2025 9:41 PM UTC
I'VE GOT A WORKAROUND.
1) Download Goldwave (https://goldwave.com/release.php).
2) Drag-n-drop your AVCHD MTS file INTO Goldwave
3) Save it as a WAV
4) Replace the static in your Premier timeline.
This really scared the $hit out of me today after a once-in-a-lifetime video deposition.  Not cool, Adobe.
Jul 14, 2025 9:22 PM UTC
This scared the living $hit out of me, Adobe.  Seriously, do better.  This is ridiculous.
Jul 13, 2025 10:20 PM UTC
They were promising a fix in two weeks about a month ago.
Everyone affected by this should get a month refund on their CC for every month that goes by without fixing it.
Jul 13, 2025 9:52 PM UTC
Any update to the mts sound issue?
Jul 13, 2025 7:29 PM UTC
Question about the sound from the *mts file (LEGRIA HF G30 camera).
I'm uploading the files to Premiere Pro 2025 (v25.3, Win 10) and instead of normal sound I hear only noise....
About a month ago I processed other recordings and it was ok, and today such a surprise.
I should add that I play the raw file from the camera through video players and the picture/sound is ok!
Has anyone encountered such a problem?
