Premiere Pro – Program Monitor guide line / Add Guide not working properly
- June 20, 2026
- 7 replies
- 131 views
In Premiere Pro on macOS, I can add a guide in Program Monitor, but using the guide for clip alignment is not working as expected. When I change Motion > Position X values (for example 960 to 420), the guide does not help with accurate placement the way I expect. I need to know whether this is a bug or intended behavior, because guide-based alignment is confusing in the current workflow.
