Adobe Acrobat Reader 24.002.21005 - problem "shifted text" in some fonts
- August 14, 2024
- 5 replies
- 6892 views
After upgrading Adobe Acrobat Reader from version 24.002.20991 to 24.002.21005, the text of PDF documents is displayed shifted into each other in some fonts (e.g. “Calibri”). This problem does not occur with the “Arial” font, for example (see screenshot).
Tested under Windows 10 and Windows 11 on different computers and with different PDF documents. The PDF document is displayed in Edge, for example, without any problems.
