해결됨
Refund - Audio producer "View Points/Epidemic Sound" does not remove copyright strike on Youtube
  • March 12, 2024
  • 2 답변들
  • 491 조회
I bought the following audio file:
#331445641 | View Points/Epidemic Sound | Arts and Crafts
I then uploaded a video to Youtube using the audio file. Youtube detected that I used the audio file and I used the following tutorial to add my license code:
https://blog.adobe.com/en/publish/2020/06/16/adobe-stock-audio-content-id-claims#:~:text=To%20find%20the%20clearance%20code%2C%20log%20in%20to,license%20key%2C%20which%20you%20can%20use%20for%20YouTube.
After taking a look, the autor did not remove the copyright strike. I want to have a refund for this audiofile and I'm really unhappy with this content producer.
Thanks for your help
이 주제는 답변이 닫혔습니다.
최고의 답변: EvilBug1
@Simon352124332ggi Really sorry you are experiencing this. I have send the refund in your account, so feel free to switch to another asset.
Meanwhile, please refer to @Abambo's post above. After providing the licence key, YouTube should allow you to use that sound on their system. Let us know if there is anything we can help from here.
-EB
2 답변
EvilBug1답변
Adobe Employee
March 13, 2024
-EB
Abambo
What does YouTube support say? After providing the licence key, YouTube should allow you to use that sound on their system if used correctly.
