Linking to a folder on a network drive using a clickbox does not work when publishing to an EXE
  • December 13, 2017
  • 141 views
I am creating a dashboard that people in my department can use to link to common sites, such as SharePoint, Yammer, etc. I am also linking them to two folders on a shared network drive.
On success of the click box I select Open URL or File and put in the path to the folder \\folder\folder\folder. It works perfectly when I view the project through a browser or publish to HTML5. However when I publish to an .EXE the click boxes no longer work.
Does anyone know why or have a workaround?
RodWard
An EXE is a Flash SWF file under the hood.  I would suspect your issue here is due to Flash Global Security blocking the link from working.
boisvert4Author
I can create this dashboard in another development tool, publish to EXE and it works, however my preference would be to use Captivate.
