Klаus
Shader/Lighting problem and heaps of »Lantern Parameter Set« error lines ...
  • August 9, 2024
  • 565 views
[Dimension 4.0.2, Windows 10]
Hi there!
When adding another light source to a given scene, the overall brightness in that scene diminishes drastically. I sense that this could be connected to the multiple usage of modified »Glow« materials. Nevertheless that seems to be a bug to me.
The log files created literally contain ten thousands of »Lantern Parameter Set« error lines ...
Cheers
Klаus
KlаusAuthor
See this before/after comparison: Adding a »Neon Moon« to the scene makes the overall brightness diminish ...
Ares Hovhannesyan
Thanks for sharing images. Looks like an artifact.
Klаus
KlаusAuthor
I’m not sure.
The main light source (which is located left and outside of the viewing area obviously) is somehow switched off or drastically dimmed by adding that Neon Moon ... I found no workaround for this problem.
Ares Hovhannesyan
Did you refer to files that are created with previous version of Dn? Here is reference where you can find info about updatres. What's new | Dimension (adobe.com)
Klаus
KlаusAuthor
Ares wrote: »Did you refer to files that are created with previous version of Dn?«
No, this is entirely 4.0.2 related.
