Differences between 7 and 8 for long books
  • March 11, 2010
  • 4573 views
I am considering FM 7 and 8 for producing a long book.  The issue with 8 is that it requires SP2 on XP, and I can't put that on my writing system.
So that would favour 7 unless its features are noticably lacking compared to 8.  Here are the book requirements, please read carefully --
* There are 4 parallel columns spread across 2 facing pages -- each column has its own text, layout, font and size, different from texts in other columns.
* All 4 columns in the spread (2 on even pages, 2 on odd pages) must retain their positions on the spread, no matter which page of the book you turn to.
* There is absolutely no left to right wrapping of columns in a parallel column layout.  This means all columns flow down - even to even, and odd to odd.
* This page flow must be automatic -- I am simply NOT going to draw frames for all pages and manually link them across a 400 page book, it is absurd.
I need to know which one of 7 or 8 supports automatic wrapping of 2 columns on even pages to the next even page, and the two columns on the right odd pages to the next odd page (if you don't understand this requisite column flow, please leave it for other to reply who do -- thank you).  If both FM 7 and 8 are more or less the same, that would be very helpful information too.  Please give compative capabilities as it relates to parallel book columns.
BTW, another really crucial feature is being able to manually set a FIXED line height in each column -- not in point size, like InDesign does (that does not work for precise alignment) -- I should be able to specify the line height in each column in decimals of an inch.  Which one can do this?
Your help on these specific questions is much appreciated.  Please no discussion of FM 9.  I will not be getting that version.  Thanks
    Jeff_Coatsworth
    "I am considering FM 7 and 8 for producing a long book."
    This sounds like you don't have a copy of either one of them - short of going through volume licensing, I'm not sure how you can even buy a copy of either of them at this point. Adobe's only selling FM9 these days.
    OK, please read:
    So if you're using an operating system older than XP SP2, what exactly are you running?
    ScratchyBoy wrote:
    [...] please read carefully --
    …are we in school here?
    Anyway, the layout engine has not changed since FrameMaker version 5.5 or so. The one major benefit of FrameMaker 8 is Unicode support, which will be of interest if your material is going to be translated to any non-Western or non-Far-East language.
    That is why you are doing it in InDesign, isn’t it?
    Well, FrameMaker does support as many text flows as you would like to have, but automatic text flow is supported from page to page, and not from odd to odd or even to even. There are several options to handle the request, for which one would have to discuss further details.
    Thank you for this warning.
    Sincerely,
    - Michael Müller-Hillebrand
    Michael,
    Just an aside question...I do not use multiple flows, but if each column has a different flow (that is, four different flows) and the odd master page has two of the flows and the even page has the other two flows, then won't FrameMaker get it right? I am thinking that maybe the user will have to add the pages manually, but once added won't the flows work correctly? Just curious.
    ScratchyBoy,
    Yes, you can specify a fixed line height in inches, but FrameMaker converts it to points anyway, even fractions of a point if necessary. If your columns are all sized the same and have the exact same TOP position on the page, I cannot believe that specifying the line height in inches instead of points is necessary to make the alignment across the columns work; they are just different units of measure. Just be sure to select the Fixed box next to the line height.
    Van
