New Participant
April 18, 2022
Framemaker 2020 - Embedded Fonts issue
  • April 18, 2022
  • 507 views
Hey, all. We are converting documents to BentonSans Regular and need to embed the fonts into our PDF. I've set up the fonts to be embedded in Adobe Distiller. Here's the dilemma:
1) If I create a pdf using Save as PDF, the fonts won't embed
2) If I create a pdf using Print Book, the fonts embed, but I can't create PDF Bookmarks, and the links in the TOC and cross-references stop working. (Links are dead)
We need to use BentonSans, so changing to a universal font isn't an option. Any suggestions as to what settings I may have incorrect? Even better, anyone know how to embed fonts using Save as PDF?
Thanks!
    Correct answer Winfried Reng
    Bookmarks:
    When you print the book to a PostScript file to create the PDF with the Distiller, activate the option "Generate Acrobat Data" in the Print dialog to get PDF bookmarks.
    What is set in Format | Document | PDF Setup? Is the option "Generate PDF Bookmarks activated?
    Fonts:
    Can you open the Publish settings for PDF? Which Preset Name is selected? Something which is set to embed all fonts?
    Best regards
    Winfried
    Winfried RengCorrect answer
    Bookmarks:
    Fonts:
    Best regards
    Winfried
    JPD-AZAuthor
    New Participant
    April 19, 2022
    Thanks, Winfried! It was the Publish step that I was missing. Bookmarks are back, now just verifying the font embed.
    Appreciate the help!
