Help for Creating Framemaker Output for Kindle Direct Publishing (Print)
  • July 21, 2020
  • 4 replies
  • 1283 views
I have a 475 page book I've created in FM for a decade or longer. It's printed these days on Kindle Direct Publishing (KDP), formerly Createspace.  (Note this is for a print book sold on amazon, NOT the kindle--for that, see below) I exported for the 2017 edition without incident by exporting the PS file, and then running it through Acrobat Distiller.  I updated the book now in FM 2020 and tried that process again and now the file is rejected by KDP because (according to their tech support) of transparency issues.
Below are their recommendation for printing.  I figured out how to find PDF/X-1a 2001, and most of the other issues but not the "Transparent objects are flattened." one.
I'm also confused by the many different ways to generate a PDF.  Can anyone recommend a method that would do the flattening?
Thanks!
John
  1. With the native document open in the application you used to write your book, select "File > Print."
  2. Select "PDF" from the list of printers you can to print to. If you do not find "PDF" in the list, there may be a "Print to PDF" or "PDF" button in the dialog box. Select this option if it is available. Otherwise, try Option 2 below.
  3. Click "Properties", "Settings", or "Options" (naming depends on your system) to check the PDF settings that will be used to create your PDF file. If available, select "PDF/X-1a," "High-Quality Print" or "Press Quality" from the list of presets. If your system allows, make sure the following settings are chosen. Any other settings should be left to default in most cases.
    • Fonts and images are embedded.
    • Specified page size matches the intended trim size plus bleed (if applicable). You may lose the bleed you included in your native document if not printed to the proper size.
    • Bookmarks, annotations, and comments are disabled.
    • Document security (any type) is not used.
    • PDF/X format is used. PDF/X is preferred, but if you are submitting non-PDF/X files (for example, PDF/A), any comments, forms, or other non-printing objects could be removed during our review.
    • Transparent objects are flattened.
    • Spreads and printer's marks are disabled.
    • Downsampling, or decreasing resolution, of images is disabled.
  4. Provide a name and location for the PDF file you are printing to (may default to the current name and location of the native document).  Click "OK" in the print dialog box.
  5. Once created, make sure to open the PDF file to see that it appears as you intended. Otherwise, make the necessary adjustments in the native document and re-create the PDF file.
    Jeff_Coatsworth
    In that case, the simplest thing you can do is just strip out the unused graphics - why put them in anyway if you're not using them??
    See above.
    They aren't "unused", but in some cases I'm only showing a part of a larger graphic file.  It would probably be several full days of work to go back through and crop out each graphic individually, re save it, insert new file names, etc etc.
    Again, I never had problems with this in the last two editions in Createspace/KDP so if it ain't broke...
    Thanks!
    John
    Jeff_Coatsworth
    Can you condition the extra graphics so that they are hidden from publishing?
    I might be able to do that if I knew what that meant 🙂  I'm a never ending FM noob since I use it once every 3-5 years.
    Thanks!
    John
    Jeff_Coatsworth
    What I got from that thread was that you need to choose the PDF/X-1a option in your job options file and pick something like "compatible with Acrobat 4" to get the flattening effect happening.
    Thanks yes I have tried 7 different submissions with various X-1a options so far and they just keep getting rejected with no explanation.  Their support says they are "working on it".  Lesson: Don't use Amazon KDP. Before they absorbed Createspace, Createspace was great.
    Thanks!
    John
    RePosted above, I guess I can't delete this
    Well it looks like I'm not going to get a response here but if anyone's interested I have been posting updates over at the KDP forum: https://www.kdpcommunity.com/s/question/0D52T000056RC4iSAG/incredibly-frustrating-interior-error
    Thanks, John
    Adobe Employee
    July 23, 2020
    Can you please check this thread once. Not sure who the author of this thread:
    https://community.adobe.com/t5/indesign/transparency-compliance-with-pdf-x-1a/td-p/9277582?page=1
    PDF engine across Indesign and FrameMaker is similar so you would need to ensure job option is correctly configured.
    THanks
    Amitoj Singh
    Thanks, this stuff make my head hurt.  I still am not getting any guidance from Amazon, so I guess I just have to eventually hear from them some day.
    John
