Amir Mahdi Moslehi
Artboard Rotation while using touchpad for zoom in Illustrator 25.3
  • June 10, 2021
  • 64 replies
  • 122909 views
Hi, recently I faced a new problem. When I use the trackpad for zoom-in/out the artboard keeps rotating. I don't know how can I fix this problem.
Correct answer joannem27208843
Hi I solved this problem by going to macbook System Preferences> Track Pad >Scroll and Zoom > Rotate and uncheck rotate with two fingers .
Hope this helps if there isn't already another solution that i have missed.
Jo
Hi guys,
How can I turn off, Rotate View?
Doug A Roberts
In what way is it activating that you don't want? Via trackpad gestures?
Doug A Roberts
Exactly!
The only way at the moment is to disable the rotate gesture in your system preferences.
I'm trying to work on a new project and I just rotating the canvas but I'm not clicking R or anything to rotate. But now I can't change it back to straight. How do I change it back without starting over and keep it from happening.
Doug A Roberts
Reset the rotation by double-clicking the rotate view tool in the toolbar, choosing reset from the view menu, or using the contextual tool controls in the bottom left of the screen:
please fix. its annoying, it happens every time i need to zoom or move the canvas (NOT ROTATE), its preventing my workflow and this is just about the last straw before i cancel my membership and switch to afinity. no one asked for this. i've never needed this feature nor will i ever need this feature.
m1b
I agree that this should be a preference setting that we can turn off. "Trackpad rotate gesture rotates view"?
In the meantime, if you are using a mac, and don't use rotate gesture in other apps, you can turn it off in system preferences > Trackpad > Scroll & Zoom:
those are great reset tricks but yes I have been dealing with the same issue. If you are on a mac you can create a keyboard shortcut key too but Adobe needs to have a setting to turn that off.
...i can't work like this
Hi, maybe I just haven't found this yet, but is there a tool that will allow me to suppress or lock the rotate view feature? The new mac book pro's have a trackpad that is so large that it is almost impossible to navigate the artwork without accidentally knocking it into a 5-15 degree tilt..... If this doesn't exist, I hope it gets added asap.
pixxxelschubser
Sorry, that's the only answer right now:
Hi.
Apparently, is not possible to disable the Rotate View feature.
By @pixxxelschubser
This new option of rotating the view in Illustrator is probably great for some users but it's just awfull for me! It keeps rotate when I really don't want, it makes me mad!! How can I unable this option ?
Anna Lander
Well, Rotate View tool doesn't start working spontaneously,  just don't call it (make sure to use the H shortcut for Hand, not Shift+H which is for Rotate View). You can also edit the Tools panel and delete the Rotate View tool from there.
Doug A Roberts
It may do if you're using touchpad gestures to zoom.
It keeps rotating by accident and I absolutely hate it.
pixxxelschubser
Hi.
Yo utlizo mi trackpad y si muebo mis dedos para hacer zoom hay ocasiones que me rota todo el lienzo por la nueva función que tiene illustrator y no quiero que rote!
Cómo bloqueo esta función o cómo puedo regresar a su angulo original?
Myra Ferguson
It doesn't appear there's a way to lock it. I saw that there is a feature request for a lock on the Illustrator Uservoice site. You could upvote it and add any comments there for the Illustrator team.
fanbrahms
hello everyone-
This might be easily solved, but as I could not find solution on YouTube, or anywhere else - please aid me in this.
When zooming out, sometimes this happens - and I simply can't reverse it..
pixxxelschubser
Try to double click the Rotate View Tool (in a "tool group" with the Hand tool)
fanbrahms
Thank you! Worked with the shift pressed together with the rotate view tool. Have a great day!
