How do I copy and paste into the same position in InDesign?
  • May 28, 2023
  • 4 replies
  • 37899 views
How to copy something from a right-hand page and paste it to the exact same place on a left-hand page?
Correct answer James Gifford—NitroPress
Paste in Place, Ctrl-Alt-Shift-V, will paste in the same location relative to page edges, but I don't know if there's any command that will adjust for offset margins, if that's what you're seeking. I'm sure it could be scripted.
Set the object style - you can set the position and the x y coordinates in the Style Options
Oops I see @jmlevy already suggested this.
There's also this method - follow the link to the new way too.
https://creativepro.com/how-to-flip-or-mirror-an-object-in-indesign/#:~:text=Just%20click%20the%20Flip%20Horizontal,choose%20Object%20%3E%20Transform%20%3E%20Flip.
Thank you for your response. However, I was wondering if there might be a simpler and more efficient approach to accomplish this task?
InDesign works differently - it creates spreads of a book - Illustrator works with Artboards.
Anchored objects are a fantastic way of controlling position of objects as they change page.
They are essentially part of the text - as it's anchored with the paragraphs - so you delete the paragraph you could unintentionally delete the image just a caveat.
I talked a bit here how to do it
https://community.adobe.com/t5/indesign-discussions/making-an-inline-image-extend-beyond-the-left-margin/m-p/12707089
I had more comprehensive posts in the past but I cannot find them.
Jumpenjax
Are you on a Mac or Pc?
if Mac click option click and hold on copy drag to other page. It should give you coordinates to show it in exact position on second page as you move it.
Lee- Graphic Designer, Print Specialist, Photographer
PC. 🙂
jmlevy
You could create an object style which uses position parameters, like this:
Thank you for your response. However, I was wondering if there might be a simpler and more efficient approach to accomplish this?
jmlevy
Honestly, no. You don't think that it is simple and efficient?
thanks 🙂
