P: Magenta/Pink color cast when exporting raw images from Lightroom Desktop
  • June 24, 2020
  • 15 replies
  • 19220 views
Since the software update ie. only recently, when I process an image, it looks perfect until I try EXPORT it, at which point it automatically acquired a terrible red tint.
(Shooting with a Nikon Z6. Processing on a 2019 Macbook air (retina) fyi)
Tried changing the colour space in the export window. Same red tint result for all colour space options.
PLEASE HELP!
{Moderator Note: Edited the thread title, NMB-17412}
Correct answer 99jon
Adobe is aware of the issue and is trying to resolve the problem. I suggest you follow at this link.
https://feedback.photoshop.com/photoshop_family/topics/lightroom-destkop-magenta-cast-on-export-nikon-z6
Plzz help me perset Masking free
I am having this same issue.  Lightroom and Photoshop.  A monochrome print develops a pink hue on export.  Tried the graphics card on and off, made sure no hues were altered, etc.  Did anyone find a solution that worked?
It's 2022 and this issue seems to still be there....
Hi
this magenta tint issue is still present in the latest update of Lightroom for Mac. Really screws up the workflow. Any chance Adobe can identify the problem? This is 2021 November now??? (This is not present in cameraraw for PS - maybe you can check the codes.) Or is this just linked to the LR export function? It affects Win version of LR Classic as well. (So this os a general coding issue guys)
I do not think that the best way to handle this is to reduce saturation + tint + vibrance is the solutiom we need to go for!!! (Actually this is the only way to handle this for now)
Rikk Flohr_Photography
This issue was fixed in August 2020. It is likely your issue is unrelated to this one. I would recommend your starting a new thread with additional information.
Todd Shaner
Madou555
I'm so sorry to but in like this but how does it work if i want to ask a question on this forum? What are the steps that i have to do. Again, im so sorry, I'm new here, I've never been on a forum before. Thanks.
Thank you and stay safe!
Hi, I'm using Lightroom (cloud based) v3.3 on a Macbook Pro 16" (2.3 GHz 8-Core Intel Core i9,
AMD Radeon Pro 5600M with 8GB graphics, 32 GB 2667 MHz DDR4, running latest version of Catalina 10.15.5). Upon exporting photos, several (seems random) images are rendered with a pink/magenta hue.
It looks like this only happens when exporting from Macbook Pros. I tried a varient of the same model of Macbook Pro and the same result - some images rendered with a pink hue.
When I export the same images using a 2018 iPad Pro the images come out with my edits as expected and no pink hue. I've attached copies of the images. One is an export from my Macbook Pro and the other is from the iPad Pro. Both are using the exact same image, no other edits have been made to the image. And both are exported with the same file profile - JPEG, full size, 100%, screen sharpening (standard amount), sRGB profile.
I can already confirm that it is NOT a monitor issue as I can see the pink hue on differing devices (Macbook, iPad, iPhone, Samsung TV). Even though both the iPad and Macbook Pro have a Display P3 gamut, I'm convinced it has something to do with the way Lightroom is rendering these photos on my Macbook Pro.
I'm following, I experience the same problem when exporting my images to jpg.
Hi Annelies,
Thank you for confirming this issue. Unfortunately, I also see the same issue on tiff files as well as jpgs. It's the same issue that seems to plague both file exports, which strengthens my suspicion that it has something to do with how Lightroom is rendering the edits to the final file.
Hello, Im having an issue using Adobe Lightroom on my MacBook Pro.
I edited a photo to my liking, went to export it to my laptop, and the exported image is dramatically different from what I created. I have tried many different attempts on how to get the proper image exported. Any tips or advice would be appreciated. Thank you.
JohanElzenga
This may be a color management issue, not an export issue. What were your export settings and in what application do you view the exported image?
-- Johan W. Elzenga
herewardcarrington
This is completey broken. A real show stopper.
Adobe Photoshop Lightroom 3.3 on macOS 10.15.5 here.
No matter if I export JPG, TIFF with sRGB, Adobe RGB or even ProPhoto RGB the export never ever matches the colours of the edit in Adobe Photoshop Lightroom 3.3.
In my case Fuji X100V (.RAF) and Canon EOS R (.CR3) files. I don't get what I see, totally not usable at the moment.
Same files in Capture One. Exported colours (depening on the settings of course) are looking exactly the same.
Todd Shaner
Adobe has acknowledged the issue in the Photoshop Family forum and is working on a fix. I suggest adding your 'Me To' vote and 'Follow' at the below link.
I am experiencing similar problem with the new version of PS v21.2. It could be connected.
When I export from LR to jpeg all is good, but when I try to open from LR to PS I get this colour shift as seen from the image below. If I open from LR to PS 20.0.9 the colours are correct. Seems a problem of the new update. I havent touched my settings...
Todd Shaner
Are any of you using a Windows 10 system or are you all on Mac systems? Also please let me konw what OS X version you're using if on a Mac and the LR version (Go to Help About Lightroom).
iMac Retina 5K, 27" 2019;  macOS Catalina version 10.15.3; LR verson 3.3 20200611 .. .
A solution please !
