  • October 31, 2007
  • 680 replies
  • 62290 views
Pete
    November 28, 2007
    Thanks very much Peter Figen and Tim Lookingbill for your informative posts.
    Tim...you've introduced something new to this topic with the panel types. You mentioned the Dell 2007WFP having the apparently better S-IPS panel type...shouldn't my problematic 2407WFP have the same type of panel? Does your 2007WFP not have the same colour boost in Monitor RGB applications that we are talking about here?
    Dirk...you said "My Dell works fine after I figured out the best way to calibrate it." Do you mean to say you're not seeing a saturation boost when using SFW (with "convert to sRGB" checked)? How did you calibrate it?
    Peter Figen...It seems like my calibrated profile is the only one that provides Photoshop with a description of the actual display characteristics on my monitor, so that it can then compensate accordingly to show accurate images. For example, when I am selecting monitor profiles, and I choose my calibrated profile, images in Photoshop are very colourful...then when I close the Display Preferences window, the colour snaps back to a normal colour appearance, suggesting Photoshop (or any colour-managed application) is making it's own corrections based on the profile info. I hold on to the dream that one should be able to create a monitor profile that is close to sRGB and yet have Photoshop still display accurately after compensating. I wish to have more control over non-colour managed display while still having accurate colour managed display.
    November 28, 2007
    "What model is your Dell?"
    Dell 2407WFP
    take two monitors and call me in the morning.
    November 28, 2007
    Wow! I finally got broadband-(at&t DSL), now I can make it to the end of lengthy threads like this. <br /> <br />Here's some visual evidence to show what everyone's been talking about concerning the quality of the display and how it can influence calibration and the gamut plot size and shape of the final monitor profile even compared to sRGB. <br /> <br />The following images are from several troubleshooting sessions in other forums I've conducted in the past on this very issue. <br /> <br />The first is a digital camera shot of a MacBrookPro showing an eyeball calibrator induced color error transform chart I made in the past converted to sRGB. The two pages on the screen of the MBP illustrate how the quality of electronics of a display can diminish the gamut of the final profile compared to even sRGB. <br /> <br /> <a href="http://www.pixentral.com/show.php?picture=1NOJd0p0ASzz8ed4OMKG9oY5CnBKw" /></a> <img alt="Picture hosted by Pixentral" src="http://www.pixentral.com/hosted/1NOJd0p0ASzz8ed4OMKG9oY5CnBKw_thumb.jpg" border="0" /> <br /> <br />In that troubleshooting session long ago and far away I was convinced from the correct looking preview on the right Photoshop was providing reasonably accurate previews considering the quality of the final calibration and profile which made even sRGB look ugly in nonCM browsers. The MBP's panel electronics as with all laptops are made to conserve battery life and may play a role in messing with puck based calibration packages. <br /> <br />The second image is a screenshot of two final GretagMacbeth i1Match calibration gamut plot graphs from two different CRT's from another troubleshooting session long ago and far away. On the top my 21" Samsung 1100p bought for $50 at a thrift store which I still have and still displays decent accurate color as good as my 2004 G5 iMac. On the bottom an i1Match plot from someone with the same complaints posted here using an old Trinitron CRT ready for the recycle bend. <br /> <br /> <a href="http://www.pixentral.com/show.php?picture=15U1aJqWz4BwPxp8IpcLxqwPS6E6wa" /></a> <img alt="Picture hosted by Pixentral" src="http://www.pixentral.com/hosted/15U1aJqWz4BwPxp8IpcLxqwPS6E6wa_thumb.jpg" border="0" /> <br /> <br />Conclusion...Get an LCD with an S-IPS panel like my 2004 iMac and the Dell 2007wfp which I recently calibrated with the Spyder2Pro with very good results. Search on the web for other brands that have this panel type because the manufacturers don't make this info readily available.
    "I remain convinced that there must be a way to get these Dells to behave properly. So the focus remains on calibration. Is there a way for me to create a profile which is closer to sRGB (so that it's useable for web work) AND is accurate for CMYK work, or colour work in general? Some have suggested that Spyder is crap. (I still need to email the Spyder folks to see if they have any useful feedback for me.) Do the higher end calibration systems calibrate to an sRGB standard, in addition to gamma and colour temperature? Is that it right there? "
    A hardware calibration system is able to set the black point, white point, white point color temperature and gamma. It can't change the inherent limits of what colors the monitor can display. The reason that CRT displays are all very close to sRGB is that the phosphors uses in the tubes - the elements that actually cause the monitor to glow a certain color when hit with electrons - are all very close to one another, and in turn, almost exactly the same as what is in the sRGB specification. The colorants in the LCDs are not the same and even though you can set the same basic parameters, the pure red green and blue colorants that define the gamut of the display are what they are.
    I'm pretty sure that all the calibrators will simply set the overall parameters and give you the full gamut available on the display. Remember that the profile only describes to applications that can use one the characteristics of the display. It HAS to describe the behaviour of YOUR monitor otherwise it wouldn't be good for anything. You choices are pretty much to convert you web bound image to sRGB in Photoshop while being color managed and not worry how they look untagged on THAT screen, or buy a small gamut LCD screen that is closer to sRGB. Either one will display CMYK with no problem, as long as you have the correct profiles and good calibration.
    November 28, 2007
    "A Dell is as good as anything else if it's not defective."
    My Dell works fine after I figured out the best way to calibrate it :-)
    November 28, 2007
    Please pardon this lengthy post, once again I am striving to be as clear as I can. I may be repeating myself a bit, please bear with me.
    Monitors, just like stereo equipment, come in a wide variety of prices and quality ranges. I have a cheapo BenQ lcd at home which I can honestly say is not good enough for graphics work. However, I believe that the Dell and Apple monitors should be suitable for graphics work, even if more expensive monitors are that much better. Let's say this legendary Sony Artisan is an uncompressed audio CD...then the Apple monitor is a high quality 192k MP3...and my BenQ is a paltry unlistenable 24k MP3. That 192k MP3, while truly being less than the uncompressed CD, still sounds pretty good and only an audiophile can (claim to) tell the difference.
    Perhaps if I saw a "reference monitor" next to an Apple monitor, I might have a harder time going back to the Apple, just like I might struggle to enjoy my ordinary mid-range home stereo after listening to a $15,000 audiophile system. Nonetheless, I don't think the Apples and Dells are "crap". Thousands of users are getting acceptable use out of them, and getting predictable final product from the printshop.
    The Dell I am using now at work is displaying accurate CMYK colours and I am satisfied in that regard. The problem is with RGB workflow. As I understand it, my Dell monitor as calibrated by Spyder Pro 2 displays untagged RGB images more colourfully than it (arguably) should. (It doesn't display acceptable CMYK colours in Photoshop using any built-in profile.) I have noticed some cases of Firefox-displayed images (not colour managed) appearing over-saturated to my tastes, whereas they display fine in Safari (colour managed), so yes I can agree my monitor profile has issues.
    Note: I beg of you to please only offer constructive feedback and information, and yes, even opinions. Please try to phrase them in a polite way...there have been MANY disparaging words spoken here.
    Did you ever get a decent calibrator. This topic is so boring I can't remember.
    Yes, an Apple Refurb is what I also am thinking. 23" would be good... I guarantee you the second I by one Apple will introduce the newly designed latest greatest 24" or 27"
    Just for the record, I have replaced 3 sets of DIMMS and a Riser board in my new Mac Pro, and am still having ECC Errors... returned a 24" iMac aluminum because of the darker right side screen issue, of which I checked 3 local Apple stores and all the 24" display iMacs had the dark screen issue, and the one at the local Best Buy. That's why I got the Mac Pro, and of course I had to add 4 gigs of ram, x1900 card, 1.5 terabytes of HD.... so my budget and patience are stretched WAY beyond breaking... I got the 2407 monitor to try and keep costs under control. Time to ebay some more stuff out of the garage!
    Money and the DIMM error problem have added to my inability to troubleshoot this whole issue. Maybe easy for you guys, not so easy for me. I am presently get freezes and crashes in photoshop when opening image files.... I hate this crap!!!! I need a beer!!!
