  • October 31, 2007
  • 680 replies
  • 62290 views
Pete
    November 28, 2007
    Look at Apple refurbs. I got a Cinema HD 23" no complaints here. no dead pixels. and the refurbs have been gone over with a fine tooth comb. they are a bit cheaper than the brand new. Ezio will cost a chunk of cash.
    > I should be able to use any monitor I please, and the results, by way of a calibrated profile, should be the exact same as anyone elses.
    I said should be... besides, I'm just exagerating here... Conveying subtle anger and frustration.
    Why calibrate if nothing can ever match? "Should be" is good. I can want that!
    Mike-
    Touche
    It just didn't seem intuitive or necessary at the time to spend a fortune on an ACD when this 2407 had such high ratings, high resolution, 92% ntsc and was brand new tech.
    I've said it before and I'll say it again... the color, and pop of this thing is truly awesome. With calibration the colors appear absolutely normal, and 4-color work is perfectly matched. It really is weird.
    Ramón G Castañeda
    Peter Mars,
    Absolute nonsense. It's obvious you haven't even begun to explore the subject. And you've never used a reference monitor either.
    On the subject of untagged images, the embedded profile barely adds 4KB to the size of a file. At the very least, one should keep a tagged copy of any untagged files one feels compelled to send out or upload.
    Peter -
    Apple makes bad monitors. Wake up.
    Thanks Craig, I'll check out the Eizo
    Doesn't matter what I say at this point... a few have been kind and helpful, and a few have been loud and angry. That's just life I guess.
    95% of the world is on cheap, uncalibrated PC monitors..... so, if I buy an Apple Cinema Display, it'll be the perfect match!
    > Why is it so hard for you to understand this... I should be able to use any monitor I please, and the results, by way of a calibrated profile, should be the exact same as anyone else. Period!
    Clearly you have no concept that no one is on the same page for manufacturing standards.
    <So a different monitor will make all these troubles go away... well I guess my safest choice then would be an Apple Cinema Display? ><br /><br />Well your best bet would be a Sony Artisan, but since it isn't made anymore, in fact there are no CRT displays made today that are up to professional standards, so you have to go LCD.<br /><br />Check out Eizo Color Edge.<br /><br />Still, you should be able to find something affordable that gets you in the ballpark of sRGB.
    Why is it so hard for you to understand this... I should be able to use any monitor I please, and the results, by way of a calibrated profile, should be the exact same as anyone elses. Period! If Dell doesn't represent the essential PC model, what the heck does! So I bought a Dell Monitor that was Highly rated and refused to believe that photoshop and or a browser couldn't handle it. Now I give up... thanks for you concern.
    No one twisted your arm to jump in here every 10 minutes either! You should have stopped reading this thread after post #29 if you were so annoyed! A few good folks stuck with it and I am for one am eternally grateful to them. Have you lost sleep over this, have you argued with your wife over this, have you walked in circles and cursed over this???? Well I have, for weeks!!! Go away then!
