Save stuck on 0%. HELP! [2019]
  • November 13, 2019
  • 53 replies
  • 70974 views
I'm using the latest version of Photoshop 2020 (21.0.1). I tried saving my file and it stuck on 0%. I figured because the autosave is on I can close it and I might lose only the last few things I did. God was I wrong. I lost all my work. I did some work again and decided to manually save it again. Little did I know I have the same issue. Is anyone else experiencing this? I don't know what to do. I don't want to lose everything again. I tried duplicating everything and saving that file bot it didn't work. Please help as this is important work. I'm using a 2017 Mac if that has anything to do with it.
New year, same problem. Grateful for the work arounds, but any news on adobe fixing this?? Seems like it would be top priority.
I regularly have this same problem on my internal SSD running Catalina. My workaround is to go to "Edit" and then "Assign Profile" then choose another colour profile then click OK, you will now be able to resave the document. You can then switch back to your preferred assigned profile and contine.
Same problem. Happens at least once a day. Running PS 21.2.4 on iMac 27" 2019 Mojave 10.14.6 and NOT saving to external HD so that's not an answer. This bug makes your product broken.
kukac
I'm having the same problem, always after I add a Curves adjustment layer with mask into a folder that has a mask also.
I'm on Windows 10.
Thanks Kukac! That helped me. When I rename a curved adjustment layer, with a mask, in a folder, that's clipped to a smart object, I cannot save. If I leave the adjustment layer named "Curves #" the document saves just fine. This only occurs with curves. Renaming H/S has no issues.
Oh, and curves adjustment layer has a blend option. Anyway, I gave up and ungrouped. Haven't had an issue when it's not grouped.
I have the same issue right now, I duplicated the image and saved it, this saved me hours of work.
laurab79270189
Happening to me...Mac High Sierra,  PShop 10.13.6....trying to save to Desktop
did Export As and saved to Desktop
also when I did Force Quit of PShop, Recovered image came up when I re-opened PShop
ugh!!!
laurab79270189
to clarify....I did Export As (while it was showing 0% saved) and saved to Destop and it worked.
Feldspar___
Same issue here on a High Sierra machine saving to an external hard drive
Same problem. I am not saving to an external drive, working locally. Catalina OS and everything is up to date. stuck on 0% save and anytime i try to re-save it says theres a program error. luckily I see theres a workaround in the thread so I don't lose all my work, but this is super frustrating and has been going on for at least a couple months.
Sterphy
I have the same problem (latest PS in Sept 2020)... I'm trying to copy the layers over to another document, but this really isn't good enough.  Adobe's software quality is beyond unacceptable now.  I'm replacing PS with Affinity, Premiere with Resolve and downgrading my CC to just an AE subscription, which unfortunately I can't replace yet.  I just can't rely on Adobe any more.
1.  Group all layers
2.  Create a new document.
3.  Move grouped layer to a new document
4.  Save
5.  Problem Solved.
Sterphy
This doesn't work
