Script call dodge & burn
  • December 3, 2019
  • 4 replies
  • 3551 views
Hello all,
Please help me write a script.
I want call the dodge & burn tool with setup:
1. Dodge: Range: Highlight, Exposure: 100%
2. Burn: Range: Shadow, Exposure: 100%
Any help would be appreciated.
Thank in advance!
Annc
Correct answer greless
dodgeTool:
var r = new ActionReference();
r.putProperty(stringIDToTypeID("property"), stringIDToTypeID("tool"));
r.putEnumerated(stringIDToTypeID("application"), stringIDToTypeID("ordinal"), stringIDToTypeID("targetEnum"));
var options = executeActionGet(r).getObjectValue(stringIDToTypeID("currentToolOptions"));
options.putEnumerated(stringIDToTypeID("mode"),stringIDToTypeID("blendMode"),stringIDToTypeID("dodgeH"));
options.putInteger(stringIDToTypeID("exposure"),100);
r.putClass(stringIDToTypeID("dodgeTool"));   //dodgeTool    burnInTool
var d = new ActionDescriptor();
d.putReference(stringIDToTypeID("null"), r);
d.putObject(stringIDToTypeID("to"), stringIDToTypeID("null"), options);
executeAction(stringIDToTypeID("set"), d, DialogModes.NO);
burnInTool:
options.putEnumerated(stringIDToTypeID("mode"),stringIDToTypeID("blendMode"),stringIDToTypeID("burnInS"));
r.putClass(stringIDToTypeID("burnInTool"));   //dodgeTool    burnInTool
greless
grelessCorrect answer
dodgeTool:
burnInTool:
ANCHINGOAuthor
Thank you so much!
The great! This is what I need.
Have a nice day!
Stephen Marsh
Raw AM code via ScriptListener for Dodge:
var idslct = charIDToTypeID( "slct" );
    var desc561 = new ActionDescriptor();
    var idnull = charIDToTypeID( "null" );
        var ref203 = new ActionReference();
        var idDdTl = charIDToTypeID( "DdTl" );
        ref203.putClass( idDdTl );
    desc561.putReference( idnull, ref203 );
executeAction( idslct, desc561, DialogModes.NO );
Change "DdTl" to "BrTl" for Burn – and idDdTl to idBrTl for Burn.
AM code for Dodge (via Clean SL):
select();
function select() {
	var c2t = function (s) {
		return app.charIDToTypeID(s);
	var s2t = function (s) {
		return app.stringIDToTypeID(s);
	var descriptor = new ActionDescriptor();
	var reference = new ActionReference();
	reference.putClass( s2t( "dodgeTool" ));
	descriptor.putReference( c2t( "null" ), reference );
	executeAction( s2t( "select" ), descriptor, DialogModes.NO );
AM code for Burn (via Clean SL):
select();
function select() {
	reference.putClass( s2t( "burnInTool" ));
I am not aware of an option for setting the actual tool settings, apart from calling a tool preset.
Stephen Marsh
Edit: Tool list updated!
//www.ps-scripts.com/viewtopic.php?f=68&t=11342&p=64930&hilit=selectTool#p64930
//selectTool('paintbrushTool');
//selectTool('pencilTool');
//selectTool('colorReplacementBrushTool');
//selectTool('wetBrushTool');
//selectTool('eraserTool');
//selectTool('backgroundEraserTool');
//selectTool('cloneStampTool');
//selectTool('patternStampTool');
//selectTool('magicStampTool');
//selectTool('historyBrushTool');
//selectTool('artBrushTool');
//selectTool('smudgeTool');
//selectTool('blurTool');
//selectTool('sharpenTool');
//selectTool('dodgeTool');
//selectTool('burnInTool');
//selectTool('saturationTool');
//selectTool('redEyeTool');
//selectTool('marqueeRectTool');
//selectTool('marqueeEllipTool');
//selectTool('marqueeSingleRowTool');
//selectTool('marqueeSingleColumnTool');
//selectTool('moveTool');
//selectTool('artboardTool');
//selectTool('lassoTool');
//selectTool('magicLassoTool');
//selectTool('polySelTool');
//selectTool('magneticLassoTool');
//selectTool('magicWandTool');
//selectTool('quickSelectTool');
//selectTool('cropTool');
//selectTool('perspectiveCropTool');
//selectTool('sliceTool');
//selectTool('sliceSelectTool');
//selectTool('magicEraserTool');
//selectTool('gradientTool');
//selectTool('bucketTool');
//selectTool('pathComponentSelectTool');
//selectTool('directSelectTool');
//selectTool('penTool');
//selectTool('CATracePenTool');
//selectTool('freeformPenTool');
//selectTool('curvaturePenTool');
//selectTool('addKnotTool');
//selectTool('deleteKnotTool');
//selectTool('convertKnotTool');
//selectTool('typeCreateOrEditTool');
//selectTool('typeVerticalCreateOrEditTool');
//selectTool('typeCreateMaskTool');
//selectTool('typeVerticalCreateMaskTool');
//selectTool('rectangleTool');
//selectTool('ellipseTool');
//selectTool('triangleTool');
//selectTool('polygonTool');
//selectTool('lineTool');
//selectTool('customShapeTool');
//selectTool('framedGroupTool');
//selectTool('eyedropperTool');
//selectTool('colorSamplerTool');
//selectTool('rulerTool');
//selectTool('textAnnotTool');
//selectTool('handTool');
//selectTool('rotateTool');
//selectTool('zoomTool');
//selectTool('patchSelection');
//selectTool('recomposeSelection');
//selectTool('spotHealingBrushTool');
//selectTool('editToolbar');
//selectTool('countTool');
//selectTool('3DMaterialSelectTool');
//selectTool('3DMaterialDropTool');
//selectTool('targetedAdjustorTool');
//selectTool('eyedropper2Tool');
//selectTool('eyedropperPlusTool');
//selectTool('eyedropperMinusTool');
//selectTool('blackAndWhiteTool');
//selectTool('hueSatTool');
//selectTool('curvesTool');
//selectTool('blackPointTool');
//selectTool('grayPointTool');
//selectTool('whitePointTool');
//selectTool('selectionLabSmartBrushTool');
//selectTool('selectionLabRefineTool');
//selectTool('selectionLabDumbBrushTool');
//selectTool('selectionLabMagicLassoTool');
//selectTool('selectionLabLassoTool');
//selectTool('selectionLabPolyLassoTool');
//selectTool('patchMatchTool');
//selectTool('patchMatchSamplingBrushTool');
//selectTool('patchMatchLassoTool');
//selectTool('patchMatchPolyLassoTool');
//selectTool('patchMatchAlignmentTool');
//selectTool('patchMatchHandTool');
//selectTool('patchMatchZoomTool');
//selectTool('neuralGalleryTool');
//selectTool('neuralGalleryHandTool');
//selectTool('neuralGalleryZoomTool');
//selectTool('neuralGalleryBrushTool');
//selectTool('neuralGallerySelectionBrushTool');
//selectTool('neuralGallerySelectionRemovalBrushTool');
function selectTool(tool) {
    var desc9 = new ActionDescriptor();
        var ref7 = new ActionReference();
        ref7.putClass( app.stringIDToTypeID(tool) );
    desc9.putReference( app.charIDToTypeID('null'), ref7 );
    executeAction( app.charIDToTypeID('slct'), desc9, DialogModes.NO );
Stephen Marsh
Select a tool preset:
// forums.adobe.com/thread/2641154
// Select the Rectangular Marquee Tool
// This overcomes the issue of the "current tool only" preset option being active
// forums.adobe.com/message/8785597#8785597
// forums.adobe.com/message/8786309#8786309
// www.ps-scripts.com/viewtopic.php?f=68&t=11342&p=64930&hilit=selectTool#p64930
var desc = new ActionDescriptor();
var ref = new ActionReference();
ref.putClass( app.stringIDToTypeID('marqueeRectTool') );
desc.putReference( app.charIDToTypeID('null'), ref );
executeAction( app.charIDToTypeID('slct'), desc, DialogModes.NO );
// Select the Preset: Rectangular Marquee 4 X 6
// To Do: Add error checking to return an alert if the desired preset does not exist
select();
function select() {
	reference.putName( s2t( "toolPreset" ), "Rectangular Marquee 4 X 6" ); // Name of Tool Preset to select
Chuck Uebele
Just create a preset for the tool.
ANCHINGOAuthor
I know, but I need script for other project. 🙂
JJMack
Have you some design for how the script will function  dodge and burn are normally interactive  processes.
Dodge: Range: Highlight, Exposure: 100%;  Burn: Range: Shadow, Exposure: 100% ???
Have you written a prototype script?
JJMack
ANCHINGOAuthor
Hello JJMack,
I just want simple:
Example case 1: current tool is Brush, I will run script -> current tool is Dodge with setup above.
