Echo problem with Snowball mic - how to disable mic sound?
  • August 30, 2020
  • 529 views
I am using elements 15. I am trying to record voiceover but I constantly hear myself. How do I disable it? I use a USB snowball microphone.
Turn off or mute your speakers while you're recording.
YONAT0D44Author
Thank you very much for answering. If I do it I would not be able to listen to the playback music. I am trying to record voice over music.
I think I need to find a way to mute the sound monitoring or to mute the sound of myself while recording.
The only other option is to wear headphones when you record your narration.
