May 16, 2022 4:37 AM UTC
A low level exception occured RawPCM Exporter: 17
I am trying to automatically translate my audio sequence into Spanish (as I did before) and when I click on "Create Transcription" it generates the error: "A low level exception... Exporter 17"
Only with the Spanish language.
does anyone know how to fix it? has happened to them?
Thanks a lot!
yosoyelcapiCorrect answer
Jun 10, 2022 8:37 PM UTC
I found an origin that generates the problem in my case... I solved it by removing the effects of the Audio Track Mixer, clean audio and I can only generate the subtitles without error.
In case of having effects, it keeps giving me an error.
May 18, 2022 9:20 AM UTC
I am having the same issue with American English!
May 18, 2022 2:27 PM UTC
I am having the same issue with Portuguese!
May 23, 2022 7:11 PM UTC
Same thing here
