May 16, 2022 4:37 AM UTC
A low level exception occured RawPCM Exporter: 17
I am trying to automatically translate my audio sequence into Spanish (as I did before) and when I click on "Create Transcription" it generates the error: "A low level exception... Exporter 17"
Only with the Spanish language.
does anyone know how to fix it? has happened to them?
Thanks a lot!
yosoyelcapiCorrect answer
Jun 10, 2022 8:37 PM UTC
I found an origin that generates the problem in my case... I solved it by removing the effects of the Audio Track Mixer, clean audio and I can only generate the subtitles without error.
In case of having effects, it keeps giving me an error.
Jun 30, 2022 6:42 PM UTC
Absolutely fed up of the errors and problems with PP. I have been using for over a decade and it seems to be getting worse. I have deadlines and I am struggling with this error that was not there in previous versions
Jun 30, 2022 6:45 PM UTC
having to export audio - open PP 21, re open project in 22, import transcription. Thank goodness i keep older versions! Come on adobe. Stop breaking things that work!!!
Jun 30, 2022 6:48 PM UTC
PS file transcribed in PP 21 just fine(to the cloud) Its a workaround anyway
Jun 23, 2022 12:20 PM UTC
I have/had the same problem with german language.
It worked, when I cleared my In- and Out Points in the timeline and just had the checkbox "Recognize when different speakers are talking" marked.
yosoyelcapiAuthorCorrect answer
Jun 14, 2022 3:47 PM UTC
Thank you, yosoyelcapi! Deleting thirdparty audio effect (RX9) from the track works for me with 22.4.0.
Disabling does not. So I duplicate the timeline and then delete RX9 effect from it temporal purpose.
Jun 10, 2022 5:56 PM UTC
Resolved without having to roll back.. unfortunately don't know how I did it.
Somehow Premiere couldn't find the English Language pack. I opened the "Spell Check Settings" box under the Text Panel, there were no language to select from. I don't think trashing Preferences did anything, but I did uncheck "Check Spelling" box and restarted Premiere. When I opened the Spell Check Settings box later, the English language options had returned.
Oct 13, 2022 4:43 PM UTC
I could solved it unchecking "Spell Check Settings"
Jun 10, 2022 4:41 AM UTC
Same issue, Australian English.
Jun 8, 2022 5:37 PM UTC
having the same issue!
Jun 8, 2022 12:24 AM UTC
i am having the same issue with American english. clear media cache, swap playback engine...normal stuff not fixing it.
Jun 8, 2022 12:33 AM UTC
well going back to 22.0 fixed it. why are there so many versions if so few work? i'm no Bob Gates but maybe just make a couple versions that all work
Jun 5, 2022 10:37 PM UTC
I can transcribe one sequence successfully but then have to quit Pr and reopen and then transcribe the next sequence. If I try to transcribe more than one seq consecutively, it fails with the same RawPCM error
Nov 20, 2022 11:08 PM UTC
This solution worked for me! thank you
May 31, 2022 5:24 PM UTC
Still happening in 22.4, but only occasionally...One project file works fine, the next one won't run...
May 18, 2022 3:16 PM UTC
believe it's the new Premiere update!
I managed to solve it by returning the version (22.0.0 Build 169)
May 18, 2022 4:04 PM UTC
I wish we could have a stable version at once.
