A low level exception occured RawPCM Exporter: 17
  • May 16, 2022
  • 58 replies
  • 27596 views
I am trying to automatically translate my audio sequence into Spanish (as I did before) and when I click on "Create Transcription" it generates the error: "A low level exception... Exporter 17"
Only with the Spanish language.
does anyone know how to fix it? has happened to them?
Thanks a lot!
Correct answer yosoyelcapi
I found an origin that generates the problem in my case... I solved it by removing the effects of the Audio Track Mixer, clean audio and I can only generate the subtitles without error.
In case of having effects, it keeps giving me an error.
Resolved-ish.
I hate workarounds, but I found one that worked for me. Disable any music or sfx you may have, export out a .wav, then bring that file in and try to transcribe the sequence. It's annoying but worked for me.
FR : J'ai résolu ce problème en enlevant la musique. Une fois la transcription des sous-titres faite, j'ai ajouter la musique. Ca fonctionne.
EN : I solved this problem by removing the music. Once the subtitles were transcribed, I added the music. It works.
POR/BR : Eu resolvi este problema removendo a música. Uma vez que as legendas foram transcritas, adicionei a música. Agora funciona.
This does work, but until 2023 there is still this error is very troublesome
Just came across this exact error. The fix that worked for me was to disable spell check in the text panel and then restart PP. After that Transcribe/auto captions worked with no issues.
gil754
Has this now been fixed in 23.1.0?
Foto de Gastronomia
Consegui corrigir o erro clicando em ANINHAR a sequencia de áudio.
A fix that worked for me was to export my sequence, then import that export in a dedicated sequence inside premiere again.
My initial sequence had many audio FX already implemented, maybe it screwed up the whole thing, and it was too much work to remove all these effects. Exporting and re-importing did the trick.
I did have audio effects on the seq, but removing it didn't make any difference. The classic "close program, open program" worked.
Nobir5C18
 I solve it creating a new sequence
O meu eu resolvi retirando os efeitos do Audio Mix, deu certo aqui!
