lehestro
Dec 6, 2024 2:01 AM UTC
Adding medio or Renaming in Project Panel down twirls every Bin and Sub-Bin in Project
If I add media or rename anything in the Project panel (bin, clip, whatever), every single bin down twirls and my project bin becomes a total cluster and I can't see what I'm working on. I have to option click the twirl arrow to up twirl every bin, and then twirl back down as needed. This is really a mess when working on a feature film with dozens if not hundreds of bins. The expected result is simply that the the twirl status of all the bins stays the same when importing or creating a new bin/sequence/color matte, etc.
This only occurred in a Project inside a Production.
Closing the project and reopening it fixes the issue, but wanted to bring it to your attention so there is a record in case anyone else is dealing with this.
I cannot say why this started, unfortunately.
Premiere Pro v 25.0.0 build 61 on macOS 15.1.1
System: M1 Max with 64GB memory
Dec 20, 2024 12:25 AM UTC
Hi @lehestro,
Thanks for the message. That definitely sounds annoying.  Does it happen every time you try to rename it? If you're able to capture a screen recording of what happens, that would help our engineers a lot to address it.
If you have time, please give the team a few more details. See, How do I write a bug report?
Sorry for the pain points.  Thanks for reaching out.
