Adobe Premiere Pro 2024 is Damaged and Can't Be Opened
  • October 11, 2023
  • 4 replies
  • 5454 views
Hi there,
Just wondering if anyone else is getting this problem with premiere 24. I followed the instructions in this existing post to no avail:
https://community.adobe.com/t5/premiere-pro-discussions/adobe-premiere-pro-2023-is-damaged-and-can-t-be-opened/td-p/13348245
All other 2024 apps work fine.
Correct answer Ann Bens
Unistall and use cleanertool
Then reinstall.
See how that goes.
Mohammad Aamir Khan
Adobe Employee
Adobe Employee
January 14, 2025
Easy Fix - Allow it from Security TAB
"Open Anyway" Need to be clicked from Security tab when this Error Appearted and relaunch app after allowing it
Thanks
Aamir Khan
@Mohammad Aamir Khan
and for Windows?
Mohammad Aamir Khan
Adobe Employee
Adobe Employee
January 14, 2025
Its basically a Permission glitch, Please try Launch app as Administrator on a PC or Try Launch Hidden Admin Account on PC
1. Open Terminal (With Admin)
2. Type the below command in it:
net user Administrator /active:yes
3. You will find a new Admin account called Administrator in it.
4. Login in this new Acciount
5. Open Premiere Pro and check.
( Hidden Admin account is a kind of Super Admin account with app permissions)
Thanks
Aamir Khan
Adobe !!!! this is not good and thustworthy.
Have used Adobe software since the first release of Photoshop. It just gets more and more complicated.
Can't belive we have to follow this complicated guideline and use a special Adobe cleaner app!!
What is this? We pay a lot of money for Adobe CC.
Please make an update to Premiere Pro that fixe the issue and please don't spread a lot of file all over my computer when you install things.
I manually deleted all Premiere-files on user/Documents + all files in user/Library/Preferences,
then uninstalled Adobe Premiere Pro 2024,
the installed Adobe Premiere Pro 2024.
All works now — no "Damaged"-dialogue at the start.
Did not use the cleaner app or followed all the steps proposed.
Same Isssue. Did uninstall and reinstall nothing happened.
Peru Bob
quote
By @Kuldeep30102067akqb
Did you use the Cleaner Tool?
Then reinstall.
See how that goes.
troid.orgAuthor
I can confirm that this worked for me. I had missed the cleanertool step. Thanks Ann.
