Resuelto
After export : video at half speed, audio still at normal speed.
  • June 6, 2020
  • 2 respuestas
  • 3233 visualizaciones
FYI I never had a problem with the settings I was using before(I think they were default) , and I may have accidentally switched a export setting.
So I was editing my podcast in Premiere Pro , and finished up and the playback looked perfect . So I went to export it , and when it had finished up I noticed The video was going at half speed and the audio was at normal (1.00x) I tried tweaking a bunch of settings (like frame rate) and kind of got close but I could never line it up. It would always exponentially distance throughout the runtime. I've now done 20 podcasts now , without a problem like this and could never figure out where I went wrong. The only thing I could think of is that the audio and video are at different hertz. Audio being at 44100 and video at 48000. But it's always been that difference , I would just go in and rate stretch it before making edits so the video and audio align. I'm not having this problem in playback, it's only after export.
I appreciate any help , this would mean a ton to me if we can get this figured out. Btw I'm not an expert with premiere pro so I would appreciate any help navigating pathways and step by step, how to find settings. If you need any info (I.e clip details, export settings, preferences, etc.) id be more than willing, I'll try to get back to your message asap. Below are two videos, one of playback , and one exported and then played in windows media player
Este tema ha sido cerrado para respuestas.
Mejor respuesta de ah_photo
I've read about this happening to someone else here too, can't remember where though... here or Reddit....not sure. Heck for all I know that was you too haha.
Either way, are you exporting H.264? If so, and if you're using Hardware Encoding, try Software Encoding instead to see if that helps. Or, perhaps trying exporting a copy in ProRes or DNx and see if the issue persists. May be an issue with the H.264 encoder.
2 respuestas
Can someone help out with this? I had the same problem but in my case Software Enconding didn't work. In fact I wasn't even able to use Hardware enconding because it said "Your system hardware does not support hardware acceleration".
ah_photoRespuesta
October 7, 2020
Thanks! I had the same problem and changing it to software encoding worked!
