Any way to keep scaling of clips identical in relation to Sequence size?
Is there any way, when copying clips from a 5k sequence into a 2k sequence to keep the scale and position of clips identical in relation to the frame size?
For example, if a clip is zoomed in 15% on the 5k, is there a way to copy it and have it zoomed in 15% on the 2k?
I've played with the project settings and have Default Media Scaling set to 'Set to Frame Size', but this just ensures that my 5k footage is massive in the 2k sequence, and not looking the same as it was in the 5k sequence. If I've done any framing adjustments, they are all screwed up when copying to the smaller sized sequence and I have to set them from scratch.
I'm editing a large project and it's a huge pain to move all of my sequences to the smaller size, but I'm forced to because Premiere has a rendering inefficiency/problem where 2k media in a 5k sequence that is rendered at 2k looks far worse than if I place that 2k media in a 2k sequence and render to 2k. I'm forced to make this move now because all of our visual effects are being finished in 2k. I thought it would be great to keep all of our 5k footage in a 5k sequence in case we wanted to render it in 5k, but now it's biting me.
