Audio Ducking generating inaccurate keyframes at regular intervals
  • February 7, 2023
  • 138 views
A Month or two ago, Premiere started generating keyframes for auto ducking without any regard to the dialogue track I had designated. The weird thing is that the keyframes it does generate have a pattern. Is there a way to fix this?
Kevin-Monahan
Hello @Trevor28291033p4uz,
Thanks for the message. Are you still having this issue? The team will need more info from you to reproduce the bug. Can you provide the information required here? How do I write a bug report?
I'll move your post to the Discussions board while we await your information.
