Jun 14, 2021 6:40 PM UTC
Audio Ducking not working
Premiere Pro V 14.7.0
MAC OS Mojave 10.14.6
I've never had an issue with audio ducking - it's always worked great.  Now it does not adjust the music when it gets to a lower keyframe - even if I drag the keyframe to zero, it will still play music at a high level.
Is this a bug?  Or have I hit a setting somewhere to disable it?  Keyframes throughout are ignored.  All music and dialog are categorized properly.
anthony_gcCorrect answer
Jun 14, 2021 7:27 PM UTC
I resolved this.  If anyone else has these issue, here's what I did to bring audio ducking back to life:
• removed all audio clip categories and reassigned them (this is probably what did the trick)
• removed extraneous and muted audio clips from final sequence
• created new project and copied all files into it.
May 24, 2026 6:35 PM UTC
Wow finding this thread in 2026 is incredibly disheartening. Thanks for all the help Adobe, really cool software I pay thousands of dollars a year for. Really cool.
Feb 26, 2024 10:28 PM UTC
Wow... Almost 3 years later, and this is still a problem. Shame on you, Adobe. Anybody else have any suggestions to resolve this? I have tried all of the suggestions on this page so far.
Aug 2, 2023 10:50 PM UTC
I had this problem today, I fixed it by linking some missing footage in the sequence, despite having proxies already there. Once I relinked the original high res footage ducking worked perfectly.
Oct 28, 2023 6:05 PM UTC
Still not fixed. I am going to work with audacity from now on. At least stuff works there. And it's free.
Jun 30, 2023 8:38 PM UTC
I was having the same problem.  I solved it by making keyframes.  I set my parameters for what I wanted the ducking to do as far as sensitivity and amount, and then I hit generate keyframes toward the bottom.  Worked!
May 16, 2023 8:21 PM UTC
Just in case anyone is still having this issue woith v.23, I figured out that if I select the preset "Duck against everything" on the music file, it works.  I couldn't get the music file to recognize the speaking in the track above it (must be our charming southern accents) so I a whim I tried the preset and voila!  Success.
Feb 22, 2024 3:31 AM UTC
That worked for me as well.
Apr 6, 2023 11:55 AM UTC
Common adobe. I'm paying for your software and all of a sudden the auto de-ducking is impossbile to generate. Before it worked perfect. Not doing any different.
This is deffinately a bug
i see work arounds, which I will try but seems a bug which needs to be fixed by adobe. Would be really nice if they did.
jank16619756
Aug 2, 2022 3:20 PM UTC
Had the same problem today, so it still hasn't been fixed. It's sad, I've been an Adobe advocate for like 30 years but it's getting harder and harder. Every time something like this happens I get pushed to switch to Resolve. It's very frustrating.
Aug 2, 2022 4:25 PM UTC
Hello jank,
I am so sorry! I have it working here on my test machine. Can you show us a screen capture of the experience you are having? I hope I can help.
jank16619756
Aug 2, 2022 5:27 PM UTC
Thanks, Kevin I wish I had time to except your generous offer. I actually did it manually for the first few clips and then decided that I had to go to different software to get the job done today. I will revisit this issue in the future. Thanks again for your offer.
Jun 23, 2022 1:58 PM UTC
This is insane, once again, Adobe software stopping me from completing a project and causing problems with my clients. I also have this issue, the ducking is completely ignored, if I move the sensitivity up it completely ducks all of the music and does not come back up when there are breaks in the speaking.
Jun 23, 2022 8:07 PM UTC
I have been struggling with this for the past few weeks, but it still doesn't seem to be resolved.
Jun 17, 2022 6:26 PM UTC
I had this same issue yesterday. I tried all of the suggestions and was not able to make the ducking work. I had to do it all manually. Its unfortunate.
Adobe, any fix in sight?
Jan 31, 2022 4:43 PM UTC
I have managed to use auto-ducking just once.  Now Premiere refuses to automatch the loudness of any clips whether it be dialogue or music.  I receive a "not matched - analyzed loudness - xxx LUFS".  The xxx can be any figure (although often it is -1.00).
I see that there have been persistent problems with loudness matching and auto ducking - anyone having more luck than I am?
Feb 13, 2022 1:06 AM UTC
Same issue here. I haven't found any solution.
