Jun 14, 2021 6:40 PM UTC
Audio Ducking not working
Premiere Pro V 14.7.0
MAC OS Mojave 10.14.6
I've never had an issue with audio ducking - it's always worked great.  Now it does not adjust the music when it gets to a lower keyframe - even if I drag the keyframe to zero, it will still play music at a high level.
Is this a bug?  Or have I hit a setting somewhere to disable it?  Keyframes throughout are ignored.  All music and dialog are categorized properly.
anthony_gcCorrect answer
Jun 14, 2021 7:27 PM UTC
I resolved this.  If anyone else has these issue, here's what I did to bring audio ducking back to life:
• removed all audio clip categories and reassigned them (this is probably what did the trick)
• removed extraneous and muted audio clips from final sequence
• created new project and copied all files into it.
Nov 4, 2021 6:15 PM UTC
This is really annoying this is not working. Please Adobe, fix this. At least reply and show that you care.
For me it worked for a few minutes, and now it does not respond to any changes. I've removed, and readded the categories. Nothing.
Oct 18, 2021 5:00 PM UTC
I've had this same problem, and used your solution to resolve while editing. My problem is now that my project is complete- when I go to render the file, the ducking is ignored and my music track is not ducking against diaglogue in the rendered project.
anthony_gcAuthorCorrect answer
