Audio Level bezier handles break after re-opening saved project
  • December 30, 2022
  • 169 views
For a few versions in Premiere I occasionally stumble upon this bug, volume level on bezier handles changes itself position after re-opening saved project. I attach screenshots with how it should be vs after reopening project, and beziers suddenly changed to extreme levels. Happens once or twice in every project. Using NVIDIA audio drivers on WIN 10.
BEFORE:
AFTER:
Hello @guest,
Thanks for the message. I apologize for the lack of response to this bug report. Are you still having this issue? The team will need more info from you to reproduce the bug. Can you provide the information required here? How do I write a bug report?
I'll move your post to the Discussions board while we await your information.
December 30, 2022
Always updating to the latest, currently 23.1.0 (build 86). Apparently this bug is still there.
I dont know which version it was but this bug has been fixed.
Which version are you using now?
FAQ: What information should I provide when ask... | Adobe Community
