Jan 2, 2019 10:28 AM UTC
Audio waveform not showing visually
Having issues with this since updating to 2019. Basically, after importing a clip into the timeline everything is as it should be (video plays, audio plays) but the audio waveform does not show up until it's played through so I cannot visually see the audio waves unless I play/skip through the whole clip, which obviously makes editing a lot slower.
Attached an example. Image 1 is the clip just imported to the timeline and image 2 is after playing through a few seconds (as you can see the audio only shows up after I've played through the clip and the remaining audio waves are still blank)
Any help would be appreciated!
Using Windows and Adobe Premiere Pro 2019.
Sep 20, 2021 11:25 AM UTC
Another option is to click on the timeline display settings button - it's the wrench icon in this pic.... There you'll see an option to turn the waveforms on or off.
Alex Fritz
Jan 31, 2023 10:24 AM UTC
Try restarting your PC. A good restart fixes many issues. I have this bug a lot and a restart fixes it most of the time.
Jan 2, 2023 4:44 PM UTC
Here's a fix that is not very satisfying, but it works every time for me, when I'm importing an mp4 video/audio into Premiere Pro. (Mac instructions follow). In the Finder, just open the mp4 file in Quicktime and confirm that you can play video and audio in Quicktime. Close Quicktime, then drag the mp4 file into the timeline in Premiere Pro. That's all!
sixsides
Dec 10, 2022 9:28 PM UTC
Right click > Render and replace. Try that!
(You might wanna unlink from the video clip first)
phil bauch
Nov 5, 2022 6:55 AM UTC
In my case I had a sub-sequence with an (although unused and not asigned) Audio Submix Track. Deleting this track in the sub sequence solved the problem. Not sure, but maybe PP takes the waveform form the "last" audio track, independently from what channels are really active and heard in the sub sequence.
Sep 9, 2022 2:51 PM UTC
I went through all of the "fixes" and nothing worked.
What did work was rendering the audio... with the audio selected, Sequence>Render Audio...
Boom, immediate fix.
Sep 9, 2022 3:30 PM UTC
WTF Adobe?
Stopped working.
Sep 9, 2022 3:45 PM UTC
Make the file offline the relink the file
Lilrex
Aug 23, 2022 1:47 AM UTC
So I just got this problem, I think it might be linked to file size.
I am working with a WAV file of 334 MB and there is no wave form showing, but I grabbed several audio tracks from other projects that are below this and all the waves generate fine in the same project.
May 24, 2022 7:23 AM UTC
i did rename the original file and it works for me try it
May 19, 2022 5:25 PM UTC
this just had this happen to me today, the easist way I found that worked so far evertime is to
1) make the clip offline
2) rename the audio clip in the folder
3) then go to the original clip in your project bin and right click and click replace footage with the new named clip.
Jan 27, 2022 6:16 PM UTC
Here's my solution: 1. Close out of Premiere completely. 2. Perform a search for all .pek files on whatever drive space your projects assets are located and delete them. 3. Launch the project and you should see Premiere generating new .pek files. I find it best to let your machine idle and allow Premiere to devote it's bandwidth to the task at hand until all .pek files have finished generating.
This has been a problem for me over the years where I lose the wav forms on the timeline, sometimes seemingly at random. Today it happened when I migrated a project and all it's assets to a new drive with more disk space (6TB of material on a 10TB drive). I came here to see if there were any updates to a solution since it's a pretty common bug from what I can tell. All of the .pek files were still alongside their respective counterparts, but using all the tricks in this thread I still couldn't get Premiere to recognize them. The deleation/re-generate method contiunes to be my best solve.
Sep 21, 2021 2:47 PM UTC
Found a silly trick : if you have the full Adobe Suite, from Premiere timeline (or project bin) right click to open up your sound file in Adobe Audition.  The operation made the waveform appear for me.  You can then simply close Audition and return to your project.
