Jan 2, 2019 10:28 AM UTC
Audio waveform not showing visually
Having issues with this since updating to 2019. Basically, after importing a clip into the timeline everything is as it should be (video plays, audio plays) but the audio waveform does not show up until it's played through so I cannot visually see the audio waves unless I play/skip through the whole clip, which obviously makes editing a lot slower.
Attached an example. Image 1 is the clip just imported to the timeline and image 2 is after playing through a few seconds (as you can see the audio only shows up after I've played through the clip and the remaining audio waves are still blank)
Any help would be appreciated!
Using Windows and Adobe Premiere Pro 2019.
Sep 20, 2021 11:25 AM UTC
Another option is to click on the timeline display settings button - it's the wrench icon in this pic.... There you'll see an option to turn the waveforms on or off.
Dec 4, 2021 6:07 PM UTC
Omg! Hahah Ur the best... so many people wa strying to make it and was finding solutions while it was JUST it..  i have no idea why siddenly it has got unchecked anyhow but it works. Thank You wo much!
Aug 7, 2021 1:13 PM UTC
Restarting program fixed it for me
frankfuture
May 24, 2021 9:58 PM UTC
From personal experience - Averdahl's solution may work, but I've never resorted to that myself because I actually use preferences to store the state of my editor, and prefer to not mess with it. The simplest solution I've found to work is to renaming the file and importing it again (sometimes more than once). I'm assuming this is a fairly basic cache issue and would be resolved by deleting the faulty preview and re-importing but, jesus mother of god, this should not be incumbent on the user. The fact that even manually invoking Generate Audio Waveform fails to generate a  valid waveform is just baffling.
My experience is that Adobe feeds on user sanity and has had this bug, among oh so many others, around since forever. Moreover, not only does pretty much every single major revision make me want to shoot myself, the absolutely absurd plethora of basic bugs and quirks that keep re-emerging is often mind-boggling on a Bethesda level.
Since these seem to be favorite solutions to various problems on the web:
@adobe : to be clear, I'm not suggesting introducing more bugs to widen the gamut, but if every second issue with your software requires the user to trash their preferences or nuke the cache, move files around, deal with lost work due to instant crashes, unzip and edit the project file, never upgrade, or roll back their drivers or editor, then it just might be time to invest in a better QA team. Or I don't know, maybe at least listen to their damn feedback.
But enough barking up a dead tree: even this basic issue hasn't been fixed in years and I'm confident won't be for years to come.
ZenGeekDad
Apr 13, 2021 1:25 AM UTC
Summary of "Fixes" (Star-Rated, on a 5-star scale):
  1. *** Render & replace.  I and many others here have found this work-around, and it seems the most robust approach, in that is works the most often.  But it's slow, makes extra files, and in rare cases, even this fails.
  2. *** Avoid editing audio tracks in Multicam sequences.  For my own reasons, I often ignore this advice and later regret it.  For example, muting audio track 1 in your multicam sequence, is trouble.  You might think you can just unmute some other track, and thereby still have an audio waveform in your derived sequence.  But the underlying code behind the multicam sequence does some mapping, and this doesn't seem designed to allow us to do these sorts of edits.  You might get audio, or you might not.  If you've done fairly little in the multicam sequence, you might be able to just unmute audio track 1 of the multicam sequence, and the audio waveform in the sequence derived from it may return.  But, the more you edit things in a multicam sequence, the more likely the bug will not be recoverable, by user manual efforts.
  3. ** Clip > Generate Audio Waveform ... is quick to try.  I think this worked for me once in several years.  But mostly no help.
  4. ** Edit > Preference > Audio > check "render audio when rendering video" ... may help.  Default is off.  So try turning on, then re-add your video to you sequence.  Might get lucky.  I have little experience with this one.
  5. * Edit > Preference > Audio > check "automatic audio waveform generation" ... fixes problem only if this was unchecked (and the default is checked), and then only for clips added to timeline after this is rechecked.  Most of time, this was not the problem, so it's not the fix.
  6. * Clear cache & peak files, some think preferrably manually (to be more complete).  This has yet to work for me, and many here report the same non-result.
SimonasVS
Feb 20, 2021 9:29 PM UTC
What worked for me is:
1. Unlinking Video and Audio
2. Right-clicking on the audio "line"
3. Render and Replace...
rocioribeiromendonca
Jan 29, 2021 11:44 PM UTC
Try right clicking on the clip on the timeline > Render and Replace. Worked for me.
SkotLind
Jan 31, 2021 3:01 AM UTC
this worked for me! Thank you. Thank you. Thank you!
Jul 10, 2020 11:24 AM UTC
The above solution didnt work for me -as well as most of the other suggestions. I closed PPro, deleted the .pek files, then it regenerated them when i reopened the project. Works like a charm...
Jan 22, 2020 2:03 AM UTC
I found a vídeo with the solution:
https://www.youtube.com/watch?v=AWi_ezZD0fU
Jun 5, 2020 3:35 AM UTC
(edit) solved with with explanation donated beforehand in this thread
Jan 14, 2020 11:14 AM UTC
Same problem here, almost over a year after first reported. The fact that you have to go whatever extra steps to see a waveform is embarassing. Did anyone at Adobe actually work as an editor? Time spend waiting and troubleshooting just keeps piling up 😞
Render-and-replace option seems to be working so far, thanks for that at least.
Jan 22, 2020 2:01 AM UTC
Jan 12, 2020 2:34 PM UTC
Just easily Right click on you audio track then Render and Replace.
Good luck.
